Results 1 to 7 of 7
Thread: t-bar
    VR Commoder aclaim
    Mar 2010
    Default t-bar
    can someone tell me how to remove the T-Bar from the gear stick in a vr auto
    VS Clubsport
    Nov 2008
    Auckland
    From memory, the leather portion of the t-bar needs to be pushed forwards and down to loosen it for removal. The actual gear change portion that you lift to change gears has a small roll pin on the side that you need to hammer out with a punch or something similar to allow you to slide that part off over the top. And don't lose the pin! Hope this helps.
    Fonzie's Avatar
    Fonzie is offline Just lost the game.
    300zx 2+2 Targa
    Aug 2008
    Gippsland, Victoria.
    Because you're a newer member, I feel the need to clarify this point... You don't need to remove the actual t-bar to remove the trim.
    Quote Originally Posted by Philthy View Post
    ....man, I love how white your car is
    VR Commoder aclaim
    Mar 2010
    Steery's Avatar
    Steery is offline AA 554 G
    94 VR SS M5
    Feb 2008
    Adelaide, near Cross Road Maccas.
    VR Commoder aclaim
    Mar 2010
    well im swaping the gearbox in my vr and i need to get the t-bar off so i can take it out
    Steery's Avatar
    94 VR SS M5
    Feb 2008
    If your swapping a gearbox and you don't know what trim is, are you sure it shouldn't be at a mechanic?
