Results 1 to 7 of 7
Thread: leaking power steering
    Bagged vs caprice sII
    Sep 2007
    Newcastle
    Default leaking power steering
    Hey guys brothers stato (vs) has a leak in the power steering somewhere its not a massive one so i cant really see where it is coming from its done 150000kms , just wondering through peoples experiences what usually goes first on the power steering.
    cheers
    Sladdo is offline Resident Ford mechanic
    HBD VT V6 5sp Exec.
    Jan 2009
    Murwillumbah
    Give it a good degrease & recheck it a week later...Could be anything from faulty pump, high pressure hose, rack or even loose fittings or stuffed o rings.
    Kurtp's Avatar
    Kurtp is offline VR Buicks > You ;)
    VR Series 2 V6 Sedan
    Aug 2009
    Pakkey VIC
    Yeah get it fixed early if you can, i left mine a while with a leak and didnt top up the oil one time, blew a shitload of seals. Now i have no power steering =]
    HBD VT V6 5sp Exec.
    Jan 2009
    Murwillumbah
    Hahaha in my old VN it would leak out the whole resoviour in 3 days...couldnt be ****ed topping it up...good for the arm muscles lol especially with a sports steering wheel
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Squeeze the rack bellows/gaiters - if it sounds like oil is in them it will mean the rack is leaking from the rack shaft seals which is expensive to fix. VS can also leak from the fluid reservoir where the 2 hoses attach - inspect under the hose as oil leaks from under the hose. If leaking here the fix is 2 new hoses. If it's the rack leaking I would add a can of "power steering stop leak" which will slow/stop the leak.
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The return line tends to leak too at the clamp. Also check the transmission lines that go to the radiator, they leak at the clamps too. Is it definitely PS fluid? Or can you just see the drops on the ground?
    Visit my Facebook page
    VS V6exec
    May 2010
    NSW sydney
    was just curious guys...are the high pressure hoses the alluminuim metal looking ones underneath on the steering wrack?
  1. Leaking Power Steering Pump
    By scatterybrane_007 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2009, 01:51 PM
  2. VR V6 Power Steering Pump Leaking
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2008, 12:42 PM
  3. Help Power Steering Pump Leaking
    By hrtmad in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-01-2008, 10:13 PM
  4. VN Power Steering Pump leaking
    By Muse7707 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-01-2007, 11:51 PM
  5. Power Steering leaking.. ideas?
    By thekow in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-01-2007, 05:24 PM
