Page 1 of 2 12 LastLast
Results 1 to 25 of 33
Thread: VR Heater Tap Hose Connection's
    VZ Executive Wagon 2006 & VR Executive Sedan 1993
    May 2004
    Australia Victoria Geelong
    Question VR Heater Tap Hose Connection's
    Ok heater tap is leaking and on the way out and I have the single straight through set-up.
    Now I had no choice but to purchase the 4 connection set-up as the Holden dealership said that's all that was listed for the VR/VS.
    My problem is what hose connections go were apart from 2 to heater core and 2 to engine.
    I need to know exactly they right position's.
    I diagram would go along way etc.
    It's a V6 with ABS
    VZ Executive Wagon 2006 Hot Red, 18" Genuine Holden Rims, Window Tint, Kenwood MP3 Deck, Satin Chrome Highlights, Chrome Exterior Highlights. My Ride Link
    VR Executive Sedan 1993, White, 15" Aftermarket SS Rims, Sony MP3 Deck. (Currently Being Restored) My Ride Link
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Not sure if this is of any help but on Ebay I've seen heater taps with 2 and 4 connectors for Holdens. Try a search on Ebay (unless you've already bought one).
    VS Berlina S2
    Feb 2010
    stupid question............is it a v8? I can check into this more for you tomorrow.
    May 2004
    Yes already brought prefer not buying car oarts off ebay and keeping to genuine holden if I can.
    It's a V6 with ABS
    VS Berlina S2
    Feb 2010
    The correct tap for a VR V6 is 92034915 and available from any Holden dealer. In fact, there are hundreds of them out there so tell your dealer to go check that number. Straight plastic tap with a metal vacuum unit on the side of it. Around 35-40 bucks.
    May 2004
    Quote Originally Posted by VSHeaven View Post
    Thanks for the part number but the tap is already brought and this tap is also used on the V6's I was told the straight tap is meant for the v8's but he has had people wanting to use only the straight tap and it might have something to do with gas conversions.
    All I want to know now is how to properly hook up this 4 pipe tap.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Here are 2 pix of the heater tap on my VS.....hope it helps. Top hose on tap goes to top (highest) hose on head, next down is other head hose. Same order for the ones going to the heater...top to top, lower to lower.
    Attached Thumbnails Attached Thumbnails VR Heater Tap Hose Connection's-heater2.jpg   VR Heater Tap Hose Connection's-heater-tap.jpg
    May 2004
    Quote Originally Posted by hako View Post
    Thanks for the images but I can not see which hose goes where on the engine or heater core this would help allot.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The uppermost hose goes to the uppermost connection on the head, 2nd hose goes to the lower connection on head .
    The third hose down goes to the topmost heater connection and the bottom hose goes to the bottom connection.
    I've taken some more pix which 'may' help....remember mine is a VS.
    Good Luck.
    Attached Thumbnails Attached Thumbnails VR Heater Tap Hose Connection's-heatbulkhead..jpg   VR Heater Tap Hose Connection's-hoseintohead..jpg   VR Heater Tap Hose Connection's-otherheadview..jpg   VR Heater Tap Hose Connection's-taplocation..jpg
    May 2004
    Good Luck.
    Thanks mate that is much more clear for me now and I will be taking all the part's back to the dealership this set up is not for my VR but for VS I don't have 2 pipes coming from the water pump like yours only 1 the other engine connection is at the rear of the intake manifold.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    yep you got the wrong part. if they dont have one for as vn2 vp-vr try a vz tap, all the same just a bit longer in the connections but the same thing
    p.s i work for holden
    May 2004
    Quote Originally Posted by moff_man View Post
    Would that tap have anything to do with climate control ?
    May 2004
    Got all the right parts now even thou the guy was confused by me and what he was looking at on the computer. 1 of the hoses was actually the right one anyway as it was for the rear of the intake manifold.
    Me thinks I had a learner at the desk.
    moff_man's Avatar
    Nov 2008
    Quote Originally Posted by AussieHolden View Post
    nope, my old equipe with std a/c has the same tap as my berlina with climate
  15. #15
    May 2004
    moff_man the hose connection from heater tap to top heater core pipe is this a straight hose or one with a bend in it the one I got was too short and had a bend in the wrong place.
    This is the hose from the black side then loops under the tap through the bracket to the core.
  16. #16
    moff_man's Avatar
    Nov 2008
  17. #17
    May 2004
    some pics of my wagon, also mind the mess
    Thanks mate
    I dropped by REPCO yesterday afternoon and the young fella there really knew his Commodore's the hose I requires was just a standard straight bit of hose so all is now fixed and no more leaks.
    Why is it there are guys out there that think VR's started in 1994 and not 1993 ? It's on all the manuals and on my compliance plate.
  18. #18
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Mate can you please put all the part numbers for the hoses you got may help out someone.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
  19. #19
    May 2004
    Ok during the day the hose I put on has kinked and is blocking flow grrrrrrrr.
    I wonder if this is why Holden changed the tap but this would be expensive to move over to that set up as I will have to get a new water pump with 2 heater pipes.
    What am I to do ? last thing I want to do is go back to Holden or a parts shop BOTH want to see the set up.
  20. #20
    moff_man's Avatar
    Nov 2008
    its the same setup from vn2 onwoods i do dont see why your parts blokes are having problems
  21. #21
    May 2004
    I don't either for something that really is not rare to the Holden range yet there books that they rely on say other wise has me bloody stumped.
  22. #22
    VS_Pete_1's Avatar
    Dec 2007
    ok here we go.
    Just remember this is for a vs.
    You should be able to follow this now mate.
    Look at the hoses.
    No.1 hose goes to the bottom of the head at 2. and goes to bottom of tap.
    No.4 hose goes to top of head at 5. and goes to top of tap.
    No.12 hose goes to top of tap and top inlet on firewall.
    No.11 hose goes to the bottom of the tap and bottom on the firewall.
    Hope that helps mate.
    Attached Thumbnails Attached Thumbnails VR Heater Tap Hose Connection's-caprice99.jpg
  23. #23
    May 2004
    Quote Originally Posted by VS_Pete_1 View Post
    ok here we go.
    Wrong setup that is for a VS engine not VR Thank you anyways for trying to help.
  24. #24
    VS_Pete_1's Avatar
    Dec 2007
    I`ll see if I can get a VR one tomorrow or moff_ man might be able to get one.
    Sorry I didn`t quite get what you wanted and I just got this copy yesterday.
    See U tomorrow mate.
  25. #25
    Vr Exec BT1
    Mar 2010
    Fortitude Valley, Brisbane
    AussieHolden, go to Ebay and type in commodore heater tap in the search box - you will see the type you are after immediately. I have a VR and bought mine off ebay 3-4 weeks ago and mine is the same as yours, one hose in and one hose out - cost me $16.00 plus postage.
    hope this helps
  1. VR Heater Hose Problem
    By commodore_boy85 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-01-2010, 12:21 AM
  2. Heater hose routing for LPG
    By vanda in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-10-2009, 12:02 PM
  3. VS v8 Heater hose pictures???
    By rooooboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-09-2009, 10:02 AM
  4. Possible Heater Hose???
    By ceedy_18 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-05-2009, 09:27 AM
  5. can anyone help with VP on gas heater hose setup
    By fishman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-11-2006, 09:54 PM
