Results 1 to 5 of 5
Thread: Cruise control only working half the time?
    VT SS
    Feb 2006
    Default Cruise control only working half the time?
    my cruise sometimes wont always turn on, then at times it will but the dash light will fade out, sometimes cruise light comes on but no cruise engaged light, this problem is doing my head in, anyone had similar problem? howd you fix it?
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Common for the c/control wires inside the indicator stalk to break.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    ^^ second that.
    and 3 Dangerous non ABS VN's
    VT SS
    Feb 2006
    I can hear the relay under the dash clicking which indicates to me that there is power triggered by the switch, I will change this first then and see what happens
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If not the above, check the adjustment on the CC backup brake switch - they can loosen and make the CC think the brakes are applied.
  1. cruise control not working -vr
    By stormsearcher in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2010, 09:05 AM
  2. Cruise control not working
    By harasd in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-02-2010, 07:07 PM
  3. Cruise Control not working?
    By markER717 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-12-2009, 05:27 PM
  4. Cruise Control Not Working
    By VXHBD6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-12-2009, 05:15 PM
  5. Cruise control not working
    By Crossy_014 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-10-2009, 09:31 PM
