Results 1 to 8 of 8
Thread: VR CALAIS missfire, very rough idle.
    1994 VR CALAIS
    Apr 2010
    West sydney
    Default VR CALAIS missfire, very rough idle.
    hi guys, this is my 1st post so plz be gentle, i have just re registered my car after being out of rego for over 6 mnths. did major service and fixd any obvious mech faults before getting it back on the road. but even after changing coil, leads, plugs, and oil n filters. engine is still running rough almost to the point of stalling, if i sometimes put it in PARK thn try to go to DRIVE will caus car to stall, car idles at roughly 900rpm, but fluctuates all the way down to 500rpm. i dont know much bout cars, but i really love my vr and hav spent some real money on it so any help would be greatly appreciated
    thanx
    mike.
    vx clubsport r8
    Mar 2010
    the fuel pump could be failing give the tank a good thumping with the car idleing and see if there is any change.
    vx clubsport r8
    Mar 2010
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    ^^^^does the exhaust smell odd?
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Agree with shane271184. Drain the fuel from the tank and replace with fresh fuel before you do anything else. In six months the fuel would definitely have gone off.
    VR Calais
    Aug 2009
    A similar thing happened to ours. Turned out to be badly fouled spark plug from valve stem seal oil leak. So I'd suggest checking your plugs - start with #6, as this is I'm told the first most likely to go.
    vr v6 manual.
    Apr 2010
    Dec 2009
    Fuel should easily last more than 6 months unless it's contaminated with water or rust from the tank. I'd be checking the IAC valve, if you give it and the throttle body a good clean it may fix the problem. Just ensure you don't soak any electrical parts in carby cleaner.
    Other than that change the fuel filter and check the fuel pressure.
  1. Rough idle, Rough take off and rough stop.
    By Niggadore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2010, 05:49 PM
  2. VT calais stalled while driving,stalls when accellerate,rough idle
    By nevkezth in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-05-2009, 12:40 PM
  3. VP Calais Rough Idle
    By Jay688 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-02-2009, 10:02 PM
  4. VT Calais: Rough Idle/Flat Spots and Harder to Start?
    By Lord-Data in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-12-2008, 07:38 PM
  5. Missfire at idle...
    By Sorak in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2006, 10:09 AM
