HI
I have a bog stock standard VS Series 2 ute with a level 1 dash cluster and which to upgrade to a level 2 can I just plug a level 2 cluster in or is there extra wiring I will have to do
Thanks
Level 2 cluster will fit straight in where your level 1 is with no modifications.If you want to go to a level 3 though ,you will need to modify the wiring loom to suit.
Here ya go mate, here is the run down - Installing a level 3 cluster - The Commodore Club of Tasmania Forums
Thanks for the info
