i have a delay in my gearbox when changing from drive to reverse and that go for all gears
any help is appreciated
if your trans fluid level is okay, it could be many things, but if your car has done alot of kays its probably the clutches inside the auto worn out.
should have mentioned thos before, change your fluid amd filter and see if it helps... also Checking error codes VR/VS (Revised)
yeah its done 200 000 km and the p plater who had it before probly thrashed it
