Results 1 to 8 of 8
Thread: stiff throttle
    vz ss
    Sep 2009
    Perth SOR
    Default stiff throttle
    hey guys. havent been on here in ages. neway i've lost my licence so havent driven the car for a while. jumped in the other day and noticed the throttle was a bit stiff. ne ideas as to y or how to resolve? the cable was new wen i got it too.
    BoNeZ-01's Avatar
    BoNeZ-01 is offline "..of mice and men.."
    '95 Cino(daily driver), Project: VS.
    Mar 2010
    Central West, NSW(middle of nowhere).
    Try giving a squirt of WD40 on that spring and shaft on the throttle body, maybe even un-clip the cable, and work the butterfly for a while while giving it a few squirts.
    Could also try the spring on the accelerator pedal too, if that's where it feels like it also might be binding.
    On the 7th day, God created Holden, then on the 8th day, God created Ford, to keep idiots out of Holden's.
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost..
    wtf? im not stupid, theres no such thing as a tyre valve
    vz ss
    Sep 2009
    Perth SOR
    cheers dude. yea i pulled the pedal off and give her a spray but that didnt work. i'll try the throttle body next. do u think the throttle body cud be faulty?
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    It could just be your foot not used to it after a bit without your license
    http://woteva.tk/
    If it ain't broke... I can break it for you
    BoNeZ-01's Avatar
    Mar 2010
    It 'shouldnt' be faulty if it was working before, but to be sure, disconnect the throttle cable from the throttle body, and try working it by hand, see how it feels.
    The spring will probly have a lot of tension, but still turn freely, without binding or grabbing at any spot from closed to wide open.
    If it's not that, and it's not the heavy spring on the accelerator pedal, then it could be the cable itself.
    Could try squirting some WD40 on some of the exposed section of the cable, then work the cable in and out of the casing, to work the WD40 inside.
    Try this at both ends of the cable, if you can get to both ends.
    vz ss
    Sep 2009
    Perth SOR
    na its not my foot lol. i've moved my mums vt and its so light compared to mine. i reckon its the spring on the pedal eh? wud it be from an older model? i dont think its the cable coz it was new wen i got it. and its a prick to get the pedal off too
    BoNeZ-01's Avatar
    Mar 2010
    lol.. Yeah it can be a pain to unhook. On the fire wall, the bracket that holds the accelerator, has a spring on it.
    This is all close to the carpeting, make sure none of the carpet or underlay is binding in the spring area, or where the cable moves in & out through the firewall.
    Probly the easiest way to test would be to unclip the cable at the throttle body, then try the accelerator, if it's still stiff, it's the accelerator spring, or somewhere around there that's binding.
    If it's lighter, then it's the throttle body spring or shaft that's binding up, and would probly just need a squirt to free it up.
    vz ss
    Sep 2009
    Perth SOR
    sweet i'll have a crack at it in the morn
  1. stiff springs.
    By VRV6BT1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-10-2008, 08:08 PM
  2. stiff slutch
    By 81_vh_holden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-11-2006, 01:19 PM
  3. Stiff accelerator
    By VXIIwagdf in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2006, 10:11 AM
  4. Stiff Brake
    By Smack_SPAK in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-05-2006, 12:55 PM
  5. Accelerator stiff
    By statey27 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-11-2005, 12:13 PM
