Results 1 to 11 of 11
Thread: 5 litre pacies. Can i bolt up at home?
    5.0 VS UTE S-PAC
    Mar 2010
    Default 5 litre pacies. Can i bolt up at home?
    Hi, just got some tri-ys . just wondering how hard it is to bolt up at home, since the engine bay is so cluttered. Is there a how to guide on this? Do I need any new gaskets? These are going into a vs ute, they just came off another vs 5 litre ute.
    vnss
    Jan 2005
    s.e melb
    i got the exhaust shop to fit mine, they had to raise the left side of the engine to slide the pipes in.
    not the type of job id want to do at home lol
    5.0 VS UTE S-PAC
    Mar 2010
    VX II Calais LS1
    Jan 2010
    the last set i fitted i did at home, the passenger side one dropped straight in but the drivers side was to tight so we had to undo the engine mount and jack the engine up a little then it dropped in to place.
    5.0 VS UTE S-PAC
    Mar 2010
    okay. ill have a suss when i get them. Are there any gaskets or anything that need replacing? Did it make much of a difference power wise, or sound? cheers
    VX II Calais LS1
    Jan 2010
    you will notice the sound difference thats for sure, you will need 2 new exhaust manifold gaskets (1 for each side) 2 header to Y piece gaskets and a Y piece to cat gasket and a new set of extractor bolts if you have standard headers on there now.
    I would also grab some exhaust assembly paste and put a thin smear on all the Y piece gaskets, will help make it a gas tight seal.
    PIMPIN's Avatar
    PIMPIN is offline The Lurker
    VTII Calais 3.8 WHII Statesman LS1
    Jan 2004
    VIC
    Quote Originally Posted by executer View Post
    The Pacemaker site has instructions on installation on pdf. It's the middle icon between 'print' and 'back to top' on the top right of which ever headers you've got.
    »»Resident PIMPSLAPPER««
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Pfft - quite a straight forward job. I presume they are 1 5/8" primaries which are dead easy to install. RHS is a little difficult to wiggle thru but isn't so bad. Undo the two bolts that hold the rack in and swing it down out of the way. I'd use new gaskits.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    5.0 VS UTE S-PAC
    Mar 2010
    Which rack are you referring to that i should undo the bolts? Cheers .
    ill have a crack at it on the weekend. Will upload video perhaps, of the new sound when done.Car has custom cam, so should help it a bit too.
    vs commodore
    Oct 2009
    Tamworth NSW
    He means the steering rack.
    5.0 VS UTE S-PAC
    Mar 2010
    alright. just worked that out myself. cheers
  1. [VIC] WTB: VN V8 EXTRACTORS -PACIES/HM (vic)
    By calaiscruzer in forum Swap / Wanted to Buy / Trade
    Last Post: 04-06-2009, 10:54 AM
  2. VT 5 litre head bolt torque specs?
    By beegee in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-05-2009, 12:03 PM
  3. [VIC] WTB: Pacies- Tri Y Suit GEN3
    By SAMO-87 in forum Swap / Wanted to Buy / Trade
    Last Post: 25-03-2009, 04:12 PM
  4. VS HSV Extractors VS Pacies........
    By Cobez in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-09-2008, 06:04 PM
  5. VK 5 litre Trimatic bolt pattern
    By Rossco in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-05-2006, 09:09 PM
