hey guys
on my vr v6 commodore theres a noise coming from the engine. sort of a ticking/zapping noise. it sounds like its coming from my injectors although there is no problem with the way the car runs.
any ideas?
cheers
will probably just be the injector pulse you can hear if it is a ticking kind of noise
how do i get rid of it?
could also be a fuel pressure check valve but most likly injectors.
Have a look at night to make sure its not a crook lead or coil. Look for sparks jumping.
I know you said the car runs fine but it may be worth a look.
I doubt the injectors. I cant hear mine over all the other noises the engine makes.
