Results 1 to 8 of 8
Thread: VR - Elec Window Switches
    VR Commodore
    Apr 2010
    Default VR - Elec Window Switches
    I just picked up a VR commodore exec (Build Jul 94) as a run to town car, Its in great condition with only 2 faults , 1) the Elec aerial is faulty, 2) the left rear and right rear elec window switches are dead.
    Now digging around the wreckers for VR elec window switchs has turned up heaps of them, however thay are not exactly like mine, The standard VR switches seem to be in 2 banks of 2 switches and a "child Lock" switch.
    Mine has a single bank of 4 switches (apprk 40mm x 120mm in size) and a "off - on" switch in the centre
    The actual switches seem to be the same, just the mounting appears to be different.
    Anyone got any idea whats going on here? Do i have a VR that has been modded ? or did they infact have two different switch plates for the VR ?
    Thanks
    Greg
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    The VR Exec did not come with power windows. A previous owner has installed them at a later date and for whatever reason has modified four single switches and made them into one. Why they didn't use the two banks of two switches is anyones guess. I would also hazard a guess and say that the two rear switches are not connected to anything and probably still have the original winding mrchanism behind the door trims that have been replaced.
    VR Commodore
    Apr 2010
    Quote Originally Posted by seraphic06 View Post
    Nah, there connected, If i switch the plugs to the front bank of switches, the back windows go up and down. The actual switches look very similar to the inside of the standard curved ones. Just wondering if the standard ones allow the switches to be pushed out from the curved facia ?
    The actual switches must be from something holden ? Just can't seem to find out what ?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    I've not seen a switch set like it before - tho the buttons look like Holden units.
    If the rear windows work when you plug them into the front - it has to be the way the rears are wired in for sure.
    and 3 Dangerous non ABS VN's
    seraphic06's Avatar
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    The switches are the single ones from the rear doors. The fact that the rear windows are able to be plugged into the FRONT rocker switches indicates that REAR rocker switches have been used. They have been crudely joined together - as I stated previously. The proper front rocker switches should not be able to be plugged into the rear doors.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    they looks diffrent from any holden design i have seen. if both your rear windows are not working maybe the problem lies in the jerryriged child lock setup, maybe try and jiggle it a bit and see if it just stuck
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Quote Originally Posted by moff_man View Post
    I`m with you moff_man.
    Can u give us a top pic?
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Looks after market switches to me.
    Dealer fitted power windows perhaps??
  1. Replies: 18
    Last Post: 03-11-2008, 04:12 PM
  2. QLD: elec window switches+ other stuff
    By The Darkness in forum Parts And Other Items For Sale
    Last Post: 13-03-2008, 10:15 PM
  3. Switches Behind Power Window Switches
    By extremeaudiowa in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-05-2007, 10:38 AM
  4. VL Calais Rear Window Switches Elec
    By VQUARTER in forum Electrical Wiring / Questions
    Last Post: 22-01-2007, 08:47 AM
  5. HEAPS OF VN CALAIS STUFF, spoiler, elec switches, garnish + bootlid.
    By wizza in forum Parts And Other Items For Sale
    Last Post: 16-05-2006, 03:54 PM
