Page 1 of 2 12 LastLast
Results 1 to 25 of 33
Thread: Chop Mufler Out??????
    2005 SV6
    Jun 2005
    New Zealand
    Default Chop Mufler Out??????
    I have just checked under my 97 vs ecotec and I have no cat converter, I have a resinator and two mufflers, I have recently put put K&N filter in along with S/C CAI I do not have enough money to do a whole new exhaust system.
    will chopping a muffler out help with both airflow and a better sound??????
    cheers for any advice!!!!!!!!!!
    vsII manual Guest
    2005 SV6
    Jun 2005
    New Zealand
    Yeah I think so!! still have resinator live in new zealand at the mo we are not required by law to have a cat!!!
    '05 VZ Lumina 3.6V6
    Jun 2005
    Brizzy Baby!!! atm...
    dont know what the law is in sheepville, but for a roadworthy in aust, im pretty sure you need a muffler. but what you can do is just cut the muffler out, put a straight pipe in it, then cut the muffler in half and weld it around where it should be. My mate did it on his Land Cruiser and its sweet as!!!
    Rollin Rollin Rollin
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    why would there be 2 muffs? so someone has got rid of the cat and put a muffler in plce of it.... a bit irish i would have thought cos mufflers are more restrictive than cats....
    unless they were going for that super quiet sound....
    2005 SV6
    Jun 2005
    New Zealand
    yeah a previous owner looks like they have done crazy shit!!!!
    I am going to leave a muffler on, but seen as I have two I thought it would be sweet chopping one out!!!!!! I am hoping this will give it a bit more bass nothing over the top just a little more noise and less restriction!!!!!
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    stick a gutted cat back inthere if your going to the trouble of getting under there.... at least then itll look like all the right bits are there!?!!!
    I have a 'couple'
    Jan 2005
    Bris
    Is it IRS? Because I know IRS models had 2 mufflers, one each side before the diff. Why don't you just remove the resonator if that is the case?
    VR Calais
    Jun 2005
    Quote Originally Posted by vlv8vic
    hes in new zealand, by law they dont have to have a cat converter, they dont have any of the crap EPA laws that we have over here :b:
    2005 SV6
    Jun 2005
    New Zealand
    no it has a live axle......no irs, I am going to the exhaust shop this morning to get a muffler cut out, I will let you guys know how it goes for future reference.....main concern is it may sound like shite!!!! But i guess its one of those things you just have to try.....
    cameron boyle Guest
    Default Hollowing cats
    in victoria if you hollow your cat out, apart from doing very little and making the exhaust tinny itll cost you $600 when the coppers pull you over and put a little polution meter up to the back of your car, i wouldnt bother with cutting one out i found with my exhaust the width of the pipes is what gives it its sound, i hollowed out my cat and it made the exhaust sound so shit and it did very little for performance, i ended up buying a second hand one and putting it on and i couldnt notice anything performance wise
    go for the twins with dual tipps hehe, its worth waiting for mate it is worth every cent.
    Attached Thumbnails Attached Thumbnails Chop Mufler Out??????-image-566-.jpg
    2005 SV6
    Jun 2005
    New Zealand
    well funny story, turns out I did have a cat converter which the dumb exhaust shop have cut out.. even after I specifically asked for the middle muffler chopped out.
    So now I definatly have no cat and two mufflers, I dont want to spend any money at the mo so I am still thinking of chopping the middle muffler out. this means all I will have is pipe and a muffler at the end...I have spent so much money latley on the car the mrs will not let me spend anymore!!!!!!
    2005 SV6
    Jun 2005
    New Zealand
    on going saga!!!!!!! had muffler chopped out this morning it has given a nice tone in the lower revs and more power, however removing the cat / resinator which ever one they chopped out has given it a cackle in the higher revs....any solutions to resolve this
    I have a 'couple'
    Jan 2005
    Bris
    Soooo...... what did they actually remove? If you don't have IRS then you never had 2 mufflers to begin with. Starting at the front you have the Cat Convertor (which you said was removed the first time), then you have the muffler (usually larger & oval), then the resonator (which is right at the back in front of the tailpipe and is round). Which of these did they remove?? It's really hard for anyone to offer advice if they are not given the proper information!
  15. #15
    VX SS M6
    Jun 2005
    how much does it cost to get the resi choped out
    and can you do it yourslef without fu**ing it up
  16. #16
    VR SS & VL V8 BT1
    Apr 2005
    W.A
    ive got a VR with IRS it has a cat then a small muffler before the diff then a big one at the end....at the end of this week im getting the rear one removed and replaced with a 2.5" pipe....the exhaust shop quoted me $45 to get it done.
  17. #17
    2005 SV6
    Jun 2005
    New Zealand
    cheers jnine now I know what shit is!!!!!! they chopped out the cat, and also the muffler,and have left the resinator at the back.
    so long and short of it is I guess I have pipe and a resinator
  18. #18
    2005 SV6
    Jun 2005
    New Zealand
    Quite right, at low revs she sounds very nice once I am up to 3500 tinny as, would the cat solve this, as they were not meant to take it out....I guarantee they will have flicked it off.....any idea what a secondhand cat goes for????????
  19. #19
    I have a 'couple'
    Jan 2005
    Bris
    Quote Originally Posted by hold-on
    They really should have removed the resonator from the back and left the muffler! If they removed the cat, then the muffler and just left the resonator they don't sound like they know what they are doing!
    Is it very noisy?
    Don't worry about getting a cat but back in - I would probably get a muffler and ditch the resonator (as they should have done in the first place!)
  20. #20
    2005 SV6
    Jun 2005
    New Zealand
    na she honestly is not to noisy, just a nice hum only in 1-3 rpms though. 3500rpm turns to shit very tinny.....they suggested putting a coby in removes the tinnyness. which this time round I believe as a friend had a very tinny exhaust and as soon as they put a coby in it was all good!!!!!
  21. #21
    I have a 'couple'
    Jan 2005
    Bris
    What car does your friend have? If they put in a coby res on then you have two resonators and still no muffler!
    lol - I had that type of system on my old Datto 120Y SSS
  22. #22
    2005 SV6
    Jun 2005
    New Zealand
    was a skyline, I wish I did save up now and do the exhaust properly. kind of have to make the best of it now........
  23. #23
    Vs Calais SII
    Jul 2005
    Lightbulb
    On my vs calais with IRS if i take the back muffler off and replace it with a pipe would it sound the same as taking the resinator off the earlier live axle models. Any help would be great of you
  24. #24
    2005 SV6
    Jun 2005
    New Zealand
    if I could do it again which I guess I can, I would probably go for 2 1/2 straight pipe with a couple of resinators, a friend with a vr has done this and his car sounds pretty phat!!!!!!!!!!! however I am no expert I am still trying to get my exhaust as nice as I would like it.......I think with 6's you can't get the sound of the 8's no matter how hard you try
  25. #25
    2005 SV6
    Jun 2005
    New Zealand
    updated situation, I have coby up the front and then standard resinator at the end with a vt 63 pipe, no cat or muffler anymore.
    must say it sounds good!!!!!!!!! nothing over the top but when you wanna feed it some fat it has a great sound for a 6 anyway
  1. Chop These PLZ :)
    By NVE_069 in forum General
    Last Post: 05-11-2006, 03:05 AM
  2. anyone up for a chop????
    By helay39 in forum General
    Last Post: 09-03-2006, 09:48 PM
  3. chop me plz
    By Notorious in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2006, 08:22 PM
  4. WANTED: a hotdog mufler for my vh
    By PEAKN6 in forum Swap / Wanted to Buy / Trade
    Last Post: 06-11-2005, 10:49 AM
  5. chop to the drop
    By SYM35 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-05-2005, 12:22 PM
