Results 1 to 15 of 15
Thread: Speedo Re-calibration
    ozute Guest
    Default Speedo Re-calibration
    G'day guys,
    Someone mentioned to me earlier that if i got some non stock tyres/rims for my VR that I would have to get the speedo recalibrated. I was given the impression that it's just a matter of a techy plugging in to the onboard compa and telling the car the new sized shoes. Is this the case, and does anyone know if it's costly please?
    Vs v8 ex cop
    Jul 2005
    NSW South Coast
    at a guess, it would only make 2 or 3ks differnce in a commodore. give or take depending on diamatter
    but when i had my 4wd i was near 30- 40 k out due to very large tyres(37")
    i see ur in syndey, theres a bloke out beverly hills way, he works out the diffencer(dont ask me how) and works out the gears on the cog to correct it.
    i never had mien done but my mates have and hes very good. I can try get his number for u if u like.
    dont know if its computer controlled on the commodores, if its a senscor or geared for the car to get the speed.
    hope this helps a bit
    cheers
    hayden
    Im probly wrong so dont listen to me
    VR Acclaim Series II 1995
    May 2005
    I changed my stock 15inch wheels for 17 inch rims on my VR and it made no difference at all. just check ure speed agaist a friend in their car when u get the rims if you get parnoid. probably wont be out by enough to bother with
    ozute Guest
    michaelw's Avatar
    michaelw is offline Donating Member
    VX S2
    May 2005
    Newcastle NSW
    Am I missing something (most likely) but even in the rims are different sizes the outside of the tyre is still the same isn't it?
    I thought it was just the sidewalls were smaller on a 17' vs 15'?
    Mike
    ozute Guest
    That's true mate, but sometimes the combinations are not equal to the original dimentions
    Jun 2005
    E Subs, Melb
    check out http://www.1010tires.com/TireSizeCalculator.asp - this is a tyre size calculator which allows you to compare different tyre sizes and what the speedo difference will be.
    it's a good way to determine if the difference is worth worrying about or not!!
    ozute Guest
    Jun 2005
    E Subs, Melb
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Quote Originally Posted by Macca177
    cheers
    hayden
    dia x pi x rpm keep gearbox in direct not 1,2,o/d x 60 divide diff
    cizocizo Guest
    i got 19's and my speedo is WHACK
    surprised i havent got more fines its like 15-20 under
    burnz's Avatar
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Quote Originally Posted by cizocizo
    (asuming 19 + 60 series = appox 21inch =533.4mm x pi 3.1415 = 1.6756 mtr x (2000 engine) rpm = 3351.2 mtr x (60=mtrh) /3.08 (diff) /1000 =65.283kph
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    VRII Acclaim
    Jul 2005
    I dont know if you can calibrate it through the computer, when i was looking at the speedo assembly i dont think it has that sort of setup. I have seen jaycar selling a unit thats meant to correct it, dont know how effective it is. What does the sensor work off anyway? Does it matter in this type of car what the wheel size is at all>>?
    RufusŪ's Avatar
    RufusŪ is offline I Jizzed in my pants
    VR S1 S Pack, VX S2 Acclaim Wagoon
    Apr 2005
    The Marsh, Vic
    Chck this one out http://www.miata.net/garage/tirecalc.html . This will give all the calculations and tell you how far out you are at 100 kph.
    Damo
    Signage, Splash Backs and Display Systems
    "No, I'm not a pessimist. At some point the world shits on everybody. Pretending it ain't shit makes you an idiot, not an optimist."
  15. #15
    ozute Guest
    Thanks Damo
  1. speedo calibration
    By 2wild4u in forum Holden Commodore How-To's
    Last Post: 05-10-2008, 02:59 PM
  2. mouse calibration
    By munster in forum Jokes/Humour
    Last Post: 22-03-2007, 07:13 PM
  3. speedo calibration
    By shumway in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-02-2007, 07:19 PM
  4. speedo calibration
    By tbblitz in forum General
    Last Post: 04-09-2006, 12:33 PM
  5. VR 5L trip comp calibration
    By BathurstVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-06-2005, 04:27 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
