Results 1 to 6 of 6
Thread: Losing Coolant
    benno9911's Avatar
    benno9911 is offline Donating Member
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    Default Losing Coolant
    my coolant level keeps dropping but only when it is running and i am not getting any puddles under my car
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Best to do/get a pressure test done.
    Most cars only leak when the engine is warm and the cooling system is up to pressure.
    If you can't see any external leaks, it maybe an internal leak such as intake manifold gasket.
    VN S1 (was VR) V6 Hilux
    Apr 2009
    Keep checking the oil. A real common issue is the intake manifold gaskets failing and the water goes into the valley and mixes with the oil. Look under the oil cap for cream!
    Other thing it could be is a head gasket!
    Remove spark plugs and inspect for black and wetness. The effected cylinder spark plug will look different if there is a problem with water entering cylinder
    It's free to remove the plugs, then if nothing found, remove manifold, but the gaskets are expensive.
    See images of failed gaskets;
    Losing Coolant-p7170251-large-..jpgLosing Coolant-p7170256-large-..jpgLosing Coolant-p7170240-large-..jpg
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    it was leaking from the manifold gasket in to my oil lucky it was found soon then later
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    it seems to be a common occurence with the buicks, one theory i heard is that they cannot handle 98 octane fuel? i think my gasket is going and i hardly ever use 98...
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    well i have never used 98 think it must of been that last bloody own i have found so many dodgy things done
  1. Losing Coolant
    By Tom_1569 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2009, 07:43 PM
  2. VR losing coolant??
    By gontix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-01-2009, 07:50 PM
  3. VR losing coolant
    By robs_vr_ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2008, 01:07 AM
  4. losing coolant
    By Panama in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-03-2008, 10:31 PM
  5. VS s2 slowly losing coolant
    By immortality in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2006, 07:11 PM
