Results 1 to 5 of 5
Thread: VS Wagon Rear Shock Absorber Removal
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Default VS Wagon Rear Shock Absorber Removal
    How on earth do you undo the upper nut on the rear shock absorbers? I have tried and the whole spindle rotates. I have tried gripping on the flat part but I just twisted it off! Will I need to cut the nut off?
    vs commodore
    Oct 2009
    Tamworth NSW
    If you are throwing them away and replacing them you can fully extend them from underneath the car after the bottom mount is undone then clamp some vice grips onto the shaft of the shock.
    seraphic06's Avatar
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Quote Originally Posted by Brett_jjj View Post
    If you are throwing them away and replacing them you can extend them from underneath the car after the bottom mount is undone then clamp some vice grips onto the shaft of the shock.
    Beautiful, thank you! Yes I am.
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    When I did mine a few weeks ago, I ended up putting a pipe wrench on the shocker and used a 'rattle gun' from the top. The first 1 I tried was so tight, I broke the bit off the top also.
    http://woteva.tk/
    If it ain't broke... I can break it for you
    Vr Exec BT1
    Mar 2010
    Fortitude Valley, Brisbane
    Did mine two weeks ago - same thing, drivers side flat sheared off. Got out the old hacksaw and cut off two sections of the nut and shock fell out.
  1. Changing shock absorber in pedders
    By andyli in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-08-2009, 08:03 PM
  2. shock absorber for vn
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-08-2009, 01:36 PM
  3. leaky rear shock absorber
    By paynie in forum VE Holden Commodore (2006 - ?)
    Last Post: 06-05-2009, 09:31 PM
  4. Shock Absorber Prices
    By Secki in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-03-2009, 08:53 AM
  5. Can anyone tell me the actual size of the lower shock absorber bolt for a VT wagon?
    By muso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-09-2006, 11:39 PM
