Hey all,
I have just gotten a full time job and will soon be earning some money =). I was thinking of putting some 17's on and lowering the back of my car.
As for the rims I aint sure what I want (i'll just look around) and for the springs i want the back end a few cm's off the tyre at the rear and assume i'll need new shocks with it too?
Anyways, my question is. What are the bad thigns about having 17's lowered? like camber wear or whatnot or ride or whatever.
cheers
hey mate if irs depend on how far you want to lower it you will camber kit about $200 max cause it will chew the inside of your tyres quickly. if solid axle depending on the width of the wheels an how low you want it a adjustable panhard rod about $150-$250 and if your lowering just a little bit like you said you can get away with just changing the springs the shocks will hold fine
MR HAVICK
Yeah at the moment the car is sitting 7cm above the tyre (stock) with 15inch hubs. Was thinking of what tyre width to get as well i guess and yeah was thinking of lowering the car around 5cm (50mm). So you dont reckon that needs shocks done? also the fron maybe just dropped 3cm? i dunno
so yer you can get a away with just a set of lowerd kings springs nothing more should put it at the hight you want about
2.5cm- 3cm anything more shocks are needed if you have a irs will still wear in inside but no as bad and also get a wheel alinement
MR HAVICK
i put 17s on mine and lowered it with some super low kings springs and havnt changed the shockers...no issue for the moment just i know in victoria its not road worth but no1 will look under there..the ride is a bit harder as the shockers arnt doing as much but evently i will kill the stock ones and have the buy shorter shocks..all depends on how much u wanna spend in one go..think it about 900 from pedders to get it lowered and new shocks i think.. look at mine my car to see if u think its the height ur looknig at
i did the same in my vl superlows and about a month later i was always adjusting my steering wheel so i can keep it straight not worth it in the end
MR HAVICK
an also i got pedders to do mine $1700 springs,shocks and swaybars all installed and alined and was lowered 3'' rear and 21/2'' front
MR HAVICK
If you want to do it yourself i recomend getting one of these kits,
KYB / Kings Commodore Lowering Packages!
Got some good info in that thread to about the hieght and what you will need. And rears are really easy to change but why not lower the front aswell?
I got Lows in mine i was happy with it when i had stockies but now i wish i had gone for superlows.
The Daily VN T5V6
355 VN GRP A REP
mines not to bad just a cheap way out and no major short term disadvantages
Hi there, got a set of king springs for rear for sale - 50mm lower, also a set of FE2 struts brand new, never been fitted (Durashock) 2 weeks old if you are interested - PM me
