Results 1 to 7 of 7
Thread: VR vacuum hose loose/vacuum canister missing?
    VE Berlina
    Feb 2010
    Melbourne, VIC
    Default VR vacuum hose loose/vacuum canister missing?
    I have a vacuum hose loose, the one that runs from behind the throttle body to the supposed charcoal vacuum canister that's meant to be behind the front bumper on the passenger side? I've looked everywhere and I do not have one.
    The initial problem was that when I changed the vent controls to face it would stay on feet, realizing that when I put my thumb over this loose hose it works and comes out of the face vents, where does this loose hose connect to and do VRs have these charcoal canisters?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I don't think it's the charcoal canister (which is for absorbing petrol fumes) - it's the vacuum reservoir ball and it's normally in the position you mention. Possibly the ball has been ripped off or somehow removed. Mine was held on with cable ties. I'm pretty sure the VR is the same as the VS in this regard.
    vs commodore
    Oct 2009
    Tamworth NSW
    VN-VS all have the vacuum reserve bottle(the black plastic ball looking thing under left front guard) in the same place.
    VE Berlina
    Feb 2010
    Melbourne, VIC
    Yeah that's what I meant hako, what purpose does the vacuum reserve bottle have?
    Dec 2009
    It stores vacuum so your vacuum operated controls will function and stay in the required position when manifold vacuum drops for example during hard acceleration by acting as a resevoir. Some old cars like FJ's had vacuum operated wipers which used to almost stop when the manifold vacuum dropped off.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You can always plug the end of the vacuum hose as a temporary measure till you get a proper reservoir - wreckers have them for about $20.
    VE Berlina
    Feb 2010
    Melbourne, VIC
    That's what I've done hako, just put a screw in the end and taped it up until I can get another canister, I'm assuming the car has had a minor hit in the side as the guard has been changed, I'm guessing the canister was damaged or taken off in the process.
  1. [VIC] WTB TB to emissions canister vacuum lines
    By westbad in forum Swap / Wanted to Buy / Trade
    Last Post: 02-01-2010, 12:28 PM
  2. charcoal canister vacuum llines - where do they go??
    By ronotron in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-07-2009, 06:37 PM
  3. Vacuum Hose
    By N_Mitch in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2009, 06:46 PM
  4. does pcv hose need vacuum?
    By ashzv6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-08-2006, 05:52 AM
  5. vacuum hose??
    By shanesvnv8 in forum General
    Last Post: 13-07-2006, 10:30 AM
