Results 1 to 9 of 9
Thread: vs wont start, might be computer??? pleasse help
    1997 vs ute ecotec v6 series 2
    Apr 2010
    newcastle/smiths lake
    Unhappy vs wont start, might be computer??? pleasse help
    hey guys just bought a vs 97 its got a few k's on it but whenever i go to turn it over the key turns but there is nothing but a click an thats it or sometimes it will take a sec or two before it slowly clicks like the batteries dead but i checked the battery with multimeter an its fine....
    my old vp wagon did the same sometimes an i found the earth blew off the battery??
    little help anyone please.
    Jayce
    Apr 2010
    i meant the earth blew off the computer not the battery...maybe its time for a new computer??
    Jayce
    Apr 2010
    seriously thought someone might have an idea since its a commodore sight :S
    an old mate i know said he had a vn sedan that used to do the same an he had to disconnect the battery at night because it would drain itself over a long time like over night... what would that mean?
    anyone....?
    jayce
    ORIXVywags's Avatar
    ORIXVywags is offline Max stunners on the train
    VYII Acclaim,VR Acclaim,VS Ute,VS Berlina Wagon
    Nov 2008
    Sydney, Hurstville Grove /Shire
    Where abouts is the click coming from, engine or the passenger sider kick panel
    it could only be really the computer.....even more common the CRANK ANGLE SENSOR
    Do and error check,
    and find out what code you get
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by jaycecoghlan4567 View Post
    anyone....?
    jayce
    His boot or glovebox light was probably stuck on.He might have had a dodgey boot light switch or glovebox light switch.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    What's the battery voltage? - anything under 12.6 is suspect. Also check the battery terminals for tightness...also large cable to starter motor. Try pressing the unlock button on the key whilst the key is in the keyhole.....then turn to start. Try starting in N instead of P (inhibiter switch may be dodgy). If no suggestions made are of help please supply more info. Good Luck.
    Apr 2010
    thanks heaps guys. it still starts but next time it does it ill find the clicking... still struggles
    whats the crank angle sensor...where is it an how do i error check it lol
    and ive unplugged my glovebox light an interior light and still doing it uhhh
    jayce
    VP Exec
    Jun 2005
    A CAS fault won't cause a no crank situation.
    Check the battery voltage when trying to start the car. It should drop to no less then 10V and recover back to the 12.6V within a few seconds. Slow recovery is a battery fault. Check the level of acid in the cells too - if necessary, top up with deionised water until you just see the "eye" as the meniscus forms on the level indicator in each cell.
    To check the cable to the starter motor, check the voltage between the battery +ve post and the +ve terminal at the starter motor while cranking. Should be no more than 0.1-0.2V. Also check for any voltage drop on the earth cable between the engine and battery, same method, engine cranking.
    If that's all OK and there's nothing drawing charge out of the battery overnight it's probably a dying battery but may be a dying starter motor.
    96 VS V6,98 VT 5.0 CLUBSPORT,VS V8 UTE 5 SPEED
    Feb 2008
    Brisbane Aus-loganlea
    jayce
    factory immoblizer mayb????
  1. VL wont start yet again..
    By <atomicL93> in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-12-2009, 11:56 AM
  2. Vn wont start
    By 38VNIT in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-07-2009, 12:26 AM
  3. read pleasse vx calais 2002
    By vx calais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-03-2009, 10:45 PM
  4. Car wont start
    By jonathon_86 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-01-2006, 03:27 PM
  5. Pleasse Help
    By vsbakkie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-08-2005, 05:41 PM
