Results 1 to 8 of 8
Thread: VS V6 Calais ERROR CODES 24 and 72
    VS CALAIS SC 6
    Apr 2010
    Default VS V6 Calais ERROR CODES 24 and 72
    Hi Guys i have a bit of a tricky one that i need a hand with and im hoping someone else might be able to shed some light on it.
    I have a vs calais with a bit of work done to it but most relevant to my issue is that i have just had my gearbox rebuilt (full rebuild with shift kit and 2800 high stall better bearings ect) but even my gearbox mechanic is scratching his head at this one.
    What happen is that if the gearbox shifts while the car has not got traction ie the wheels are spinning the engine light comes on and error codes 24 and 72, and when i turn the key off then on again its all good. both codes showing to do with the vehicle speed sensor which the mechanic has changed but it hasnt made a difference.
    Now while this doesnt effect day to day driving i would like to enter the vehicle in the burnout comps etc in the future and obviously because it hits limp mode when it shifts im going to struggle to make any real smoke... has anyone heard of this before?
    vs commodore
    Oct 2009
    Tamworth NSW
    It sounds like the ECU thinks the trans is slipping when its actually the wheels spinning.Or the trans is stuffed.The error codes are both to do with the speed sensor.One is no speed sensor signal and the other is intermittent speed sensor signal.Also check the wiring and connectors under the car that go to the transmission.
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    means u gotta NEUTRAL TO DRIVE DUMP IT!
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    VS CALAIS SC 6
    Apr 2010
    Na i dont think i need to nuetral dump it somehow though thanks for the imput mate! to be honest that would wreck the box.
    in regards to the other the box shift fine under all conditions, it even shifts tight when it does the below however because it hits limp mode i lose all power.
    And i have checked all the connections and changed the spped sensor again today but still no luck = (
    not sure what else i can try?
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    Try plug in a different computer, with a different memcal. The speed sensor's in the VS boxes are the magnetic 2 wire one. They go through the ecu and then up to the dash, as aposed to the VN boxes which go straight to the dash. There may be a problem there.... Just bang in a different ecu, even if it runs shitty it will at least lead you in the write direction. also check the speed sensor plug hasn't been knocked off or partly off... you never know
    Ben
    There is no such thing as stupid questions, Only stupid people.
    VS CALAIS SC 6
    Apr 2010
    That sounds like the go, but just another question is the v6 sc computer different to normal ones? and can i use a normal v6 computer in there just to check it out?
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    VS CALAIS SC 6
    Apr 2010
    yeah thats what i figured, as always tryin to find the easy (cheaper) way out - ill check the wreckers and give it a go. thanks mate.
  1. VZ V6 Calais throwing error codes..help
    By DJ Ice in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-09-2009, 09:10 PM
  2. VS Calais CD stacker error codes
    By JcB in forum Car Audio
    Last Post: 05-06-2009, 12:01 AM
  3. VS Error Codes - 23,32,44,63,64 and 76
    By RedGoesFaster97VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-03-2009, 09:52 PM
  4. VY trouble codes/error codes. NEED HELP!!
    By GILLO in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-03-2009, 04:04 PM
  5. VR error codes
    By gogo64 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2005, 07:24 PM
Tags for this Thread
