Results 1 to 3 of 3
Thread: Exhaust hiss & valve cover gasket replacement.
    VS Series II
    Nov 2007
    Newcastle
    Default Exhaust hiss & valve cover gasket replacement.
    Hey all,
    Just got a few quieries to run by you.
    Just had the car idling whilst I pumped up the tires and noticed a hiss noise coming from the left rear, sounded like the exhaust, but could be anywhere in the vacinity as its dark. The hiss was kind of like it was losing air, or the noise an air compressor makes when its full of air and not in use.
    and NO it wasnt the servo air comp making it, as I checked it again when I got home, thinking it was either that, or maybe just a bit of cold air/moisture burning up. A 5 min drive should have got it all out yeah?
    My other quiery is Valve cover gaskets. My car seem to have sprung a bit of a leak around the spark plug area. I assume that VCG is whats needed unless there are any other parts I should look at.
    How much would one cost, where could I get one & is it easy to do yourself?
    My commo is at the 320,000km mark, and I've just serviced it. Is there anything I should check around this age and km's?
    Cheers for any help
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    the noise sounds like the fuel pump, noraml
    and yes gaskets are easy to do, grab a work shop manuel it will be your best friend with jobs like that, also holden, repco or super cheep etc should sell em,
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Valve cover gaskets are easy to do. The drivers side being easiest.
    Like said above, get a manual for the car.
    I have one and I have learnt a fair bit from it.
    It's a good read too.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
  1. Valve timing cover gasket oil leak - Big job?
    By poweredbycng in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 27-09-2009, 08:16 PM
  2. Flange Gasket and Exhaust Manifold Gasket
    By mrvdv85 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-09-2009, 06:46 PM
  3. VR Head Gasket Replacement
    By boogs86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-06-2006, 09:07 AM
  4. VR Head Gasket Replacement
    Last Post: 01-06-2006, 06:33 PM
  5. Vn Head Gasket Replacement
    By James Collins in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2003, 07:18 PM
