Results 1 to 6 of 6
Thread: removing inner door handle
    VS Executive wagon
    Mar 2010
    Default removing inner door handle
    Hey all. Im trying to put in new speakers, and currently getting the door trim off.
    I have everything done now except removing whatever i need to take off the inner door handle?
    can someone run me through the process so i can get the trim off.
    thanks heaps
    VX II Calais LS1
    Jan 2010
    the center plastic section of the door/grab handle comes out, just below the elec window controls which you will need to undo the plug on and there is 2 screws behind it.
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
    VS Executive wagon
    Mar 2010
    VX II Calais LS1
    Jan 2010
    small screw driver down the joint and pop it out, its just clipped in.
    VS Executive wagon
    Mar 2010
    edit
    yeeh thanks.
    im docile.
    VX II Calais LS1
    Jan 2010
    Your looking at the wrong part completely, you need to be looking at the part you grab to close the door when sat inside.
    The plastic surround that around the handle you have pictured needs to come off and will do when you remove the screws behind the grab handle
    i did say previous the section below the elec window controls, the grab handle...!
  1. Removing rear exterior door handle
    By K Lewy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-07-2009, 04:20 PM
  2. Help with removing auto shifter handle on VS
    By Shaundy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2009, 01:23 PM
  3. Removing Door handle and Stips
    By vzlumina in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-09-2008, 05:19 PM
  4. Removing Hand Brake Handle???
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2007, 12:22 AM
  5. Before I Go Taking The Door To Pieces!... Whats The Go With The Door Handle??
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2006, 09:37 PM
