Hey guys,
As the title suggests, I can't open my bonnet! The lever feels like it's pulling the cable and I can hear it trying but no go. I tried to do it manually but not exactly sure how the mechanism works. Any ideas?
Thanks in advance!
Old Colts in Oz - Saving Old Colts but not the 80's spec FWD kind. See www.oldcolts.com.au for details.
get someone to push down on the front of the bonnet as you pull the lever
There is no such thing as stupid questions, Only stupid people.
Another trick is to sit in the drivers seat with the window down and pull the release with your left hand whilst leaning your right arm out the window and thump the corner of the bonnet with your open palm. Usually works but fix the problem before it happens again!
Thanks guys, tried both suggestions early today with no luck. Any idea if there is a way to manually do it?
does it feel like the release lever in the car is pulling to far towards you or on an angle
i could get my bonnet open , see in the pic the white part on the side of bonnet release lever popped out and the lever would pull sideways stopping me from opening the bonnet
i had to push the side part in by hand then pull the lever to open bonnet
i ended up fixing it by drilling a small hole through that and the lever and putting a nut and bolt through it to stop it happening again
Another method or last resort is to unscrew the bonnet pin which holds the bonnet down. You need to get under the car and look up just in front of the aircon condenser and you will see the slot of the bonnet pin head. Use a long large flat screwdriver to unscrew this a few turns. It helps when doing this to have someone pressing down on the bonnet to relieve tension. See attached pix - first is bonnet pin with screwdriver in slot (bonnet up) and second pix is view from under car looking up with bonnet down and locked. Have fun.
Once you've got it open, apply some grease to the bonnet pin.
Thanks guys - great tips and pics! The lever does feel a little sketchy so it could be that. I'll give it a try as soon as I get home from work and let you know how I go![]()
My guess is that the outer cable has slipped in the keeper plate.
Remove the centre pin as described.
yer d00d, smack the top right corner of the bonnet, it actually works, hahaha, i was amazed when it worked for me
All sorted! Combination of the above. Checked the lever - all good. Loosened the latch a tad and then had a mate push down on the bonnet while I pulled lever - success. A good clean and a heap of new grease and all seems sweet. Thanks guys!
I had the same problem, none of the above methods worked and i couldnt unscrew that thing. So in rage i kicked the bumper and bam the bonnet popped open lol
