I have picked up a real bargain for a external trans cooler so could someone please tell me which line from the trans is the pump out line to the radiator trans cooler, does it pump to the top or bottom of radiator trans cooler ?
Also I am thinking about by passing the radiator trans cooler as it just cost my brother about $ 3,000 for his 4 year ford as his radiator trans cooler shit itself letting coolant through the trans lines, anyone know how common is this in our model Holdens ?, mine still has the original radiator, someone said it is very common in Fords but rare in Holdens.
appreciate any advise
thanks
It pumps into the bottom of the rad an returns out the top,,
Im personally bypassing the factory cooler but only because my rad is buggered, previous owner bent the bottom of it so i don trust it.
(also the pics in my thread are the old ones the cooler sits lower down in the bar now)
Signature Goes Here
Thanks shane, very helpfull.
cheers
Rony.
Just wondering about what you guys think is the best place to position the extra cooler, I was thinking about putting it a couple inches out from the radiator and to the very top right hand side [ looking at the car from the front ] , thought about in the middle but wouldn't it muck up the air flow to the radiator, that way ?
If you look at the pic in my thread you'll see the cooler in its first position that i had it, an i thought that maybe it wasn the best spot because the factory cooler is in the lower half of the rad, (pretty sure thats correct) so i moved the cooler down a lil an now it sits in the middle of the front bar right at the bottom of the rad. look at the pics below, easier then explaining.
from the top;
From the front. hard to get a pic of:
Signature Goes Here
Thanks again Shane, I can see clearly what you have done.
thanks mate.
ive just been looking at oil coolers on ebay, want a BIG one found this
V8 transmission oil cooler 22 row VN VP VR VS SS V8 - eBay Automatic Transmission, Transmission, Car Parts, Accessories, Cars, Bikes, Boats. (end time 29-Apr-10 01:25:34 AEST)
Looks good.
ive just replaced my 6hbd but have cut coolant lines and have got aftermarkit 1s but i dont know what fitting out of the trans is the feed or whats the return is the feed out of the trans the top fitting and the return the bottem 1 or the other way round? some 1 help
lower outlet on transmission casing is the feed line that goes to the bottom nozzle or pipe on the radiator . the top nozzle on the radiator is the return back to the transmission , top outlet on transmission caseing .
