Results 1 to 3 of 3
Thread: warning lights stay on
    vr statesman caprice
    Apr 2010
    Gold Coast
    Default warning lights stay on
    Hey all changed the cluster on my 94 vr statesman now ABS and airbag lights on all the time, can this be fixed or do I just take bulbs out? thx
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    This is probably a result of not disconnecting the battery when you changed the cluster. The airbag light needs to be reset by Holden or someone with the right equipment, it can't be done yourself. Removing the bulbs is not a good idea. Disconnecting the battery for a few minutes might reset the ABS light but I'm not sure.
    MY RIDE
    vs commodore
    Oct 2009
    Tamworth NSW
    The airbag or srs system will log an error if any of the srs system was unplugged and the ignition key was turned to the on position.Ive done the same thing before ages ago,I was swapping relays over under the dash and I removed the srs relay with the key on and it set an error and the airbag light came on.I had to pay to get it turned off and clear the error.
  1. lights on dash stay on and ignition is turned off
    By Alan22008 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-08-2009, 07:49 PM
  2. Indicators/Hazard lights just stay on
    By anonymousmoose in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-06-2008, 09:14 PM
  3. Brake lights stay on?
    By Noy in forum Electrical Wiring / Questions
    Last Post: 12-11-2007, 08:12 PM
  4. Warning Lights
    By redvxss in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2005, 12:24 PM
  5. My Interior Lights Stay On
    By VQOwner in forum Electrical Wiring / Questions
    Last Post: 18-11-2003, 01:43 PM
