Results 1 to 5 of 5
Thread: Check engine light doesnt work - not globe
    VS Clubsport, 81 DeLorean
    Dec 2007
    Default Check engine light doesnt work - not globe
    Hi all,
    I am having an issue with the check engine light in my VS Clubby. Found this the other night when i was trying to do a fault code check. Have changed the globe over a number of times. Doesnt even do the test when the key is first turned on. All of the other lights work though when it does the check.
    Any ideas of where to start looking? I have inspected the back if the cluster for damage, and everything seems to be in good order.
    Paul
    vs commodore
    Oct 2009
    Tamworth NSW
    What pins in the ALDL connector are you bridging?The light should definitely come on with the ignition key on accessories.Maybe turn the igniton key on with the cluster removed and test if there is any voltage at the engine light wiring connector with a multimeter. The engine light wire is coloured brown/white.The check engine light goes to the blue ECU connector number F5,you can check it for voltage there at the ECU connector as well.
    Dec 2007
    Quote Originally Posted by Brett_jjj View Post
    What pins in the ALDL connector are you bridging?The light should definitely come on with the ignition key on accessories.Maybe turn the igniton key on with the cluster removed and test if there is any voltage at the engine light wiring connector with a multimeter.The engine light wire is coloured brown/white.
    Hi Mate,
    Bridging 5 & 6 on the top row. The fact that it doesnt come on for a few seconds when the ignition is turned on is strange, when all of the other warning lights do. The owners manual does say it is meant to check at start up as well. Will do this multimeter check on the weekend. Thanks for the help!
    Paul
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Does you car have any modifications such as an aftermarket ECU? Sometimes these raise DTCs and set the engine management light on, so tuners disconnect the wire at the Holden ECU.
    Dec 2007
    Quote Originally Posted by BlackVXGTS View Post
    Hi mate,
    it had a haltech in it, but just had it ripped out and put back to standard. May have a look and see if anything is disconnected.
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. VR 1994 Indicator doesnt work (Hazard lights work)
    By rester in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2010, 01:40 PM
  3. vxss spoiler light doesnt work help!
    By Vt_vic in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-10-2008, 05:34 PM
  4. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
  5. engine just doesnt want to work.......
    By 9898989 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-07-2006, 05:51 PM
