Results 1 to 9 of 9
Thread: v6 vn motor and 5speed into auto vs v6
    holden vs
    Mar 2010
    Default v6 vn motor and 5speed into auto vs v6
    Ohk iv got a manual vn commy and i want to put the motor and box in my auto vs ( i know the old motor into a new car but i dont wanta pay 500 bux 4 a flywheel) my plans also are to put the ecotec topend (inlet manfold coilpacks ect )onto the vn motor, now what problems al im going to cum accross with putting the vn motor and box in to my vs cheers
    VS Senator
    Oct 2009
    im pretty sure the top manifolds are different between the two models and are costly to inter change. and my mate put a vn 5 speed behind a vs eco tec and im pretty sure he used the vn fly wheel and it works fine unless you have a series one vn motor which is the six bolt item
    holden vs
    Mar 2010
    yea its a series one motor thats y im try and use the motor so i dnt have to find and pay 4 a manual series 2 flywheel if the ecotec manafold is differnt ill put a series 2 manfold on then, i know that they fit, iv done them a few times
    VR Acclaim v6..?
    Feb 2008
    Gold Coast
    I imagine it would be considerably cheaper to get a second hand flywheel than do what your proposing, not to mention the fact that it is illegal and the ecotec is better on fuel which will save u the extra money you spend getting a flywheel. my 2c
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Ecotec top end will not fit a buick. Valve spacing is all wrong, and I believe the deck height is different between the two.
    VN S1 (was VR) V6 Hilux
    Apr 2009
    There is no option to use a S1 Manual motor in front of any auto, unless you are good at making adapters yourself, as far as I'm aware
    holden vs
    Mar 2010
    Vr exec 5.0L 5speed
    Mar 2008
    Mate it'd be heaps easier given the rarity of the parts to just buy a factory manual vs.
    There's quite a few to choose from
    Go with a t5 over the getrag if you can!!
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    If you really want to do it, you will need to swap the entire VN motor into the VS. You will also need the exhaust, loom, ECU swapped as well. It would be a sh!tload easier to get a manual flywheel.
    http://woteva.tk/
    If it ain't broke... I can break it for you
  1. S14 Supercharged v6 5speed or 304 v8 auto
    By LAP004 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-01-2010, 08:06 PM
  2. i have a vl 6cyl just had exchange motor put in, the cars factory auto the new motor
    By highmat_8686 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-11-2008, 09:32 AM
  3. VZ Sv6 Auto 5speed
    By StevieP in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-05-2007, 02:18 AM
  4. Holden 5speed off black motor, exellent condition
    By The 3 Brothers! in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-06-2006, 10:25 PM
