Results 1 to 7 of 7
Thread: warning lights after changing cluster
    vr statesman caprice
    Apr 2010
    Gold Coast
    Default warning lights after changing cluster
    Hey all, just changed the cluster on my 94 stato now ABS and Air Bag lights on( did disconnect battery) can this be fixed or do I just take bulbs out. plz help thx
    vs commodore
    Oct 2009
    Tamworth NSW
    It might be that both the SRS airbag and ABS warning light circuits are shorted to power somewhere in the printed circuit board.The SRS system will set an error and the SRS airbag light will be on if you have turned the key to the "on" position while any part of the SRS system has been unplugged or disconnected.Seeing as you had the battery disconnected while the cluster was out, this is not possible,so Id be looking along the lines of a faulty cluster or its PCB..Try the old cluster again,swap it back over and check if the same thing happens when its powered up,if the lights are off then you know the fault will be in the other cluster or its PCB.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    What cluster did you fit? Same date in the bottom? Were the globes working in your old cluster?
    and 3 Dangerous non ABS VN's
    Apr 2010
    Gold Coast
    Quote Originally Posted by 88GreenVN View Post
    Thx for the advise yes the new cluster is from a vr and have rechecked the old cluster and the lights for the abs, airbag were taken out, so will get another cluster and make sure all is working.
    Apr 2010
    Gold Coast
    Quote Originally Posted by Brett_jjj View Post
    thx for the advise, the old cluster had ots bulbs taken out so the new one must have had same problem will get another one but will get it checked b4 i fit it
    vs commodore
    Oct 2009
    Tamworth NSW
    Maybe there are logged errors in the SRS and ABS systems which could be why the bulbs were removed.(some idiots remove the warning light bulbs in the dash instead of getting the problem fixed).You might have to take it to holden or someone with a suitable scantool to check that these systems are ok, and to clear any logged SRS and ABS error codes.A scantool is the only way you can get these type of logged errors removed and get the systems warning lights on the dash reset so they are off.
    Apr 2010
    Gold Coast
    Thx yes will take it in to holden and get them to look at it thx once again
  1. Changing VE sv6 lights to HSV lights. any problems with projector lights
    By SV6.VICTORIA in forum VE Holden Commodore (2006 - ?)
    Last Post: 03-06-2011, 01:39 PM
  2. Changing the ODO clock on my lvl 2 Cluster
    By Jordzz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2010, 11:13 AM
  3. A warning when changing a pulley
    By vs_wagon in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2009, 08:29 AM
  4. changing the v6 cluster to a v8 one
    By NEDWOB in forum General Discussion
    Last Post: 16-05-2009, 09:34 PM
  5. changing cluster
    By Phoenix21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2006, 10:20 PM
