Results 1 to 5 of 5
Thread: vr 5.0 help
    vr caprice
    Dec 2009
    derro ville
    Default vr 5.0 help
    if anyone has any ideas : vr caprice 5.0litre, cut out while driving one day.. suspected fuel pump of course as spark was adequate, car started and drove for a few more days and cut out again, would idle for 15 mins roughly then cut out and wouldnt start for an hour or so. so i chucked in a new fuel pump (+ half a tank of juice) drove 20k's to work around town a bit 20k's home turned it off now its kicking over still full spark but no go... WTF?!!! when the pumps acivated before start up (second click with the key) its buzzing away fine but i can hear fuel slushing about in the tank, it made the same noise when it origionally screwed up. any ideas most appreciated before i torch the thing for the $$$ cheers
    vr caprice
    Dec 2009
    derro ville
    VX II Calais LS1
    Jan 2010
    most likely the hall effect sensor, get a new dizzy and try that.
    Have a search of the forum, there are heaps of threads about hall effect sensors failing lately on the 5.0 V8 engine.
    Ive had one fail in me last year, exact same symptoms you describe.
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    if its not the hall effect sensor check the ignition module, they are also known to play up. and while you're at it check that ur earth leads are on tight and in good nick. a loose negative lead on my motor shut mine down not long ago for a few hours until it cooled down
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    vr caprice
    Dec 2009
    derro ville
    Cheers will sus them both out just a thought though... would the gap sensor mean no spark cos that was fine. As with the ignition module
Tags for this Thread
