Results 1 to 7 of 7
Thread: temp gage
    vy calais .vs commodore
    Sep 2005
    blacktown
    Default temp gage
    gday every one i am after a bit of help i have a vs v6 commodore i have just had the head gaskets done now i am having a bit of trouble when i get stuck in trafic the temp gage goes up over half way but once i am moving it will go down i have replaced the thermostat i went back to the mecanic whit this problem but he sais its ok the fans are kicking in i am a bit concerned because i do not want to pay out a nother $1500 to do the head gasket again i also have a vy commodore and the temp gage will go upto just under half and stay no matter how hot or cold any idears as how i can fix it so the temp gage will say in one spot thanks
    VS Calais
    Mar 2010
    Does the gauge keep going up or does it sit above half? On our vs the gauge will rise to a bit above half and stay there until we start moving.
    These gauges are not 100% accurate, theye are designed to give you an idea of what is happening.
    Sep 2005
    blacktown
    it has got upto the line after half way that is as far as it has gone so far
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    if it goes over 3/4 then start to panic, at 1/2 the low speed fan will kick in and at 3/4 the high speed fan should kick in and bring it back down to 1/2.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Sounds pretty normal to me. As The1 says, the time to worry is if it goes over 3/4. Once the fans kick in the motor cools rapidly. Ecotec engines are designed to run at high temperatures to obtain maximum power and economy which is why the pressure cap is 1.35Kpa (20psi).
    Sep 2005
    blacktown
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    half gauge sounds very very normal for the commodores. and the temp gauge isnt in degrees so who knows what half gauge really is. as the others have said over 3 quarters pull over and panic haha
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
  1. vr commodore fuel gage
    By lukedunshea in forum Electrical Wiring / Questions
    Last Post: 03-09-2009, 11:41 AM
  2. sticking fuel gage/leaking bootlid
    By smc69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2009, 05:47 PM
  3. good places for an auto gage?
    By w3bstr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-04-2008, 11:55 PM
  4. Problem with temp gage
    By Phoenix21 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2006, 10:01 PM
  5. wtb roll gage
    By hinterland in forum Swap / Wanted to Buy / Trade
    Last Post: 06-11-2005, 09:27 AM
