i was driving down the road doing about 40 and my car just stalled.pulled ova n turned it on and was all good
does anyone know wat could of caused this?
cheers
Check for error codes first so that you can get an idea: Checking error codes VR/VS (Revised)
It sounds like something the CAS (Crank Angle Sensor) would cause when its on its way out..Sometimes when they play up they dont even throw an error code.If you find the CAS to be the problem,try to only use a new genuine holden CAS.The cheaper aftermarket ones can still cause problems ,even when new.
can i do the error code check even when the car is runing fine? will it still tell me if anything is wrong?
it cant be crank angle sensor got a genuin one new not long ago
cheers for the help
i had the same problem and found out it was the abs module earth... i dno how or why it just was..
