Results 1 to 2 of 2
Thread: vs speed signal
    VN v6 s2 Berlina 5spd
    Mar 2006
    Default vs speed signal
    Hi,
    just wondering about the speed signal wiring to suit vs v6 auto.
    I replaced the cluster in a freinds car with a non working speedo,
    and since replacing it, still has no speedo.
    So now im looking at tracing the wiring back,
    I've located a wiring diagram but am just wondering what i would be checking for at each wire?
    Does it have a 12volt pulse going to the dash?
    would I be able to check this with a test light?
    Is there any other common problems apart from the cluster to cause the speedoe to not work?
    also the speed alert does not work either.
    Thanks very much for any help or input.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quite possibly it's the vehicle speed sensor that's either failed or the wiring and/or connector has failed. First do a error codes check - if it comes up with a code 94 it indicates the sensor is faulty. There is a test for the sensor and wiring in the Gregory manual. If you don't have access to one, PM me your email address and I'll scan the page for you.
    Here is the 'how to' for error codes...it's very simple Checking error codes VR/VS (Revised)
  1. VZ car speed signal wire???
    By henrytad in forum Electrical Wiring / Questions
    Last Post: 19-04-2010, 02:46 PM
  2. VZ Speed Signal Wire???
    By henrytad in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 18-04-2010, 06:02 PM
  3. Speed signal and Odometer not working
    By commvr93 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-02-2010, 12:01 PM
  4. Cruise Control Speed Signal
    By antelopeslr5000 in forum Electrical Wiring / Questions
    Last Post: 16-05-2009, 11:25 AM
  5. speed signal
    By statey27 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2006, 02:49 PM
