hey dose any1 know if the fly wheels are same for a Getrag gearbox and a t5 is it just the clutch thats differnt cheers?
Getrag is a dual mass, the t5 has a solid flywheel. So flywheel and clutch are different.
Is your vn manual a series 1 or 2 motor? If it's series 2 it'll be an 8 bolt flywheel so will bolt up to the ecotec. You just need to get the flywheel mirror balanced to the ecotecs flexplate, as they run a different external balance to the vn motor.
na my manual vn is a series 1![]()
