Results 1 to 25 of 25
Thread: vs headlights auto turn off.
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Default vs headlights auto turn off.
    Hi all,
    Raining here today so had my headlights on and left them on after turning motor off and locked car.
    The headlights should turn off after a short time no?
    It was a good 15mins before I went down and turned them off.
    Any ideas????
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Berlina and Calais have programmable off time using the dimmer control on the headlamp switch.
    Maybe try resetting to a shorter time.
    The procedure should be in the owners manual.
    I have but a lowley Acclaim
    1996 Vs Commodore Series II V6 Auto
    Dec 2009
    South East Melbourne
    in my vs exec they turn off if the engines off and u open drivers door and then come back on when u start the car
    VS_Pete_1's Avatar
    Dec 2007
    Thanks for that I`ll have a look.
    vs commodore
    Oct 2009
    Tamworth NSW
    This is what it says in the VS gregorys workshop manual about the auto lamps off delay.
    1)Turn the ignition on.Switch the park lamps on and close the drivers side door.
    2)Hold the courtesy lamp switch on and turn the ignition off.
    3)Open the drivers door.This starts the delay period.
    4)Wait the desired time period and release the courtesy lamp switch.The delay period is now set and the park lamps will go out.
    Note.The delay period will not be set if the vehicle is moving.The maximum delay period is 120 seconds,the default delay period is 0 seconds.
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Quote Originally Posted by itchy123 View Post
    Yep same here on my exec.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by Verynice View Post
    by courtesy lamp switch, do you hold the dimmer switch up?
    Yes, as far as I know thats what they mean.Ive never used the headlights off delay so I have never bothered to set it.Let us know if it works,Cheers.
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    just been trying it on the caprice and hasn't worked so far, does it only apply to calais and berlina? hmmmm
    vs commodore
    Oct 2009
    Tamworth NSW
    My executive VS does it but I have never tried to set the timer, it is set to the default peroid of 0 seconds which means the lights turn straight off with the key and they come back on when the key is turned back on.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The instructions for setting the auto-off seems to differ from Gregorys to the factory Owners Handbook which comes with every new car....anyways, I've attached a pix of what the General says.
    Attached Thumbnails Attached Thumbnails vs headlights auto turn off.-litesoff.jpg
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    Ahhh cheers for that hako. Have to hold the dimmer switch down. I was holding it in the up position. Double checked my car manual and it says the same thing. Neat trick.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by hako View Post
    The gregorys is just plain wrong.It says to hold the courtesy light on,whereas its meant to be held down in the dim position.
  15. #15
    vs commodore
    Oct 2009
    Tamworth NSW
    I just checked out my executive and it turns off the headlights automatically as soon as the key is turned to the off position, they come back on when the key is turned back on again.The delay time cant be set on the executive models.Id say its because of the low series BCM used in the lower luxury models.
  16. #16
    VS_Pete_1's Avatar
    Dec 2007
    cheers guys
  17. #17
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Quote Originally Posted by Brett_jjj View Post
    Correct.
    Executive only has a two position switch for dash lamps where as berlina and above has a variable resistor (bcm) control for dash lamps.
  18. #18
    VS_Pete_1's Avatar
    Dec 2007
    well did mine no good.
    reset BCM
    Now the lights don`t out at all ????????????????
  19. #19
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by VS_Pete_1 View Post
    reset BCM
    If yours has the adjustable timer (berlina,calais,or statesman) you might have to go through the process hako has posted above out of his owners handbook that shows the setting procedure to get it to work again.
  20. #20
    VS_Pete_1's Avatar
    Dec 2007
    Done that Brett,
    got my owner`s manual out doing something wrong FIIK
    They were like yours go out when you turned the motor off.
    Mybe I held the timer down to long.
    Had my watch and timed it ????????
  21. #21
    vs commodore
    Oct 2009
    Tamworth NSW
    You might try resetting the BCM again.Just remove the fuel pump fuse in the fuse box under the bonnet for 1 second.The gregorys also says that the correct resetting of the BCM can be confirmed by a clicking sound from within the BCM,the interior light coming on and the theft deterrent alert indicator flashing.
  22. #22
    VS_Pete_1's Avatar
    Dec 2007
    did that and got a gregorys
    didn`t hear clinking or interior light coming on
    the theft deterrent alert indicator flashing ok
    I`ll have another go.
    Do you think the switch could be faulty.
  23. #23
    VS_Pete_1's Avatar
    Dec 2007
    or will I disconnect battery next
  24. #24
    vs commodore
    Oct 2009
    Tamworth NSW
    You might have to stick your head under the dash down near the pedals to hear it click while someone else replaces the fuel pump fuse.
  25. #25
    VS_Pete_1's Avatar
    Dec 2007
    Found problem.
    Got to work yesterday in the dark and opened door to get out and the courtesy light didn`t come.
    So got a new courtesy light switch and reset the BCM and set the timer for the lights and it worked.
    Thanks for the help guys.
  1. Want headlights and breaklights to turn automatically on my VT II SS
    By tigass in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-10-2009, 12:07 AM
  2. Headlights wont turn off with door
    By fatboy15 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-05-2009, 07:05 PM
  3. Opening door wont turn off headlights anymore vr wagon
    By BREWZA in forum Electrical Wiring / Questions
    Last Post: 03-01-2009, 02:42 PM
  4. why do my headlights go out when i turn on highbeam?
    By mychellewith6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-11-2007, 10:26 AM
