Results 1 to 3 of 3
Thread: Error Codes
    VS Ute
    Apr 2010
    Default Error Codes
    Where can I get my car checked for error Codes
    As it Use quite bit of fuel and idles high
    I have read through the forums and some say check O2 Sensor and other check the Temp sender to the ECU
    I dont want the buy new ones and it not fix the problems so if I can get the codes checked it could help
    The other thing is I am in regional WA
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    if your engine light isn't coming on when driving i dont think an error code check will do much. im pretty sure the vs computer only stores error codes for the next 20 times its fired up after an error occurs.
    search the forum for 'check error codes' im sure there are threads showing how to do it. its easy all u need is a metal paperclip. if it dosen't flash code 12 (one flash-brief pause-two flashes) meaning everythings good post what code u got and im sure someone with a manual will have a look and tell ya what the code means
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    some error codes do not trigger the check engine light, it's always good to check
    Checking error codes VR/VS (Revised)
  1. VY trouble codes/error codes. NEED HELP!!
    By GILLO in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-03-2009, 04:04 PM
  2. error codes 13 and 33
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-01-2009, 08:02 PM
  3. error codes 32 and 76
    By zoran119 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-12-2008, 08:10 PM
  4. VR V6 Error Codes?
    By 1994 CoMMy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-12-2007, 09:31 PM
  5. error codes 6 and 8?
    By Juzzy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-08-2005, 07:12 PM
