Results 1 to 9 of 9
Thread: a few little probs with my vr acclaim wagon
    vr acclaim wagon, vs wagon (project) & vx belina
    Apr 2010
    brisvegas
    Default a few little probs with my vr acclaim wagon
    I recently just bought a vr wagon, just as a work car , and it has alot of klms on it ,350000+. but i got it cheap.. the problems i am experiencing are....
    Top heater hose, the end that joins the engine just under the throttle body leaks coolant, there is a small spout for a hose to be clamped to, it has perished and broken off, it is attached with a 10mm bolt... has any 1 else had this problem and is the replacment part easily sorced???
    My other problem is a transmission fluid leak right at the back of the tranny where it connects to the tail shaft... theres like a sensor which is connected to a round thing, i removed it ( seems magnetic) as it looks like the seal has gone and this is why the fluid is leaking.
    Its about 6 cm diameter, what is this part called?? and can the seal be replaced??
    any help would be much appreciated
    Mar 2008
    is the sensor at the back on the side of the box
    if so i think you are refering to the speedo pick up
    there is a rubber seal that goes in there
    i did price one from holden and think they were a bit pricey for a bit of rubber
    i ended up putting a bit of black silastic there and it seems to have stopped my leak
    Apr 2010
    brisvegas
    yeah i think it is that its on the side of the box ,it undid with a 10mm spanner, leaked about a cup of fluid when i undid it, would any rubber o ring do that i can get from autobarn/repco?
    VN Wagon
    Jan 2010
    the plastic heater hose barb that is held in buy a 10mm bolt you can get from repco -autobarn for about $20 bucks in brass part number is KC38MC hope this helps
    Mar 2008
    have a look at the pic below , is that the part you are talking about
    Attached Thumbnails Attached Thumbnails a few little probs with my vr acclaim wagon-speedo-pick-up.jpg
    Apr 2010
    brisvegas
    Quote Originally Posted by CAMZVS View Post
    the one that broke today was plastic, and was a real pain in the arse to evenlook at let alone remove.... part no. KC38MC i assume has a seal etc as the whole it has to go into is about 15-20mm diam??
    thank 4 the help i hope auto barn is open tomorrow
    Apr 2010
    brisvegas
    Quote Originally Posted by deanos70 View Post
    doesnt look like it at all , its on drivers side just above tranny mount at rear
    Apr 2010
    brisvegas
    [IMG]img0134lj9[/IMG]
    is this what i need does any 1 have a part number or is it:KC38MC
    VN Wagon
    Jan 2010
    yeh KC38MC is the part number it includes the barb and oring to suit.
  1. My 96 Acclaim Wagon
    By Frank2112 in forum VR - VS
    Last Post: 17-02-2010, 07:27 PM
  2. VZ Acclaim Wagon
    By Wat Hertz in forum VY - VZ - WK - WL - V2
    Last Post: 27-08-2009, 09:24 PM
  3. vr wagon probs
    By 38VNIT in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-08-2009, 06:14 PM
  4. 91 vn berlina wagon probs.... :S
    By Nchalada in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-05-2006, 08:04 AM
  5. vt acclaim Series 2 cruise control probs....
    By werdy666 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-08-2005, 07:47 PM
