Results 1 to 12 of 12
Thread: vs auto into vr
    maginoodle's Avatar
    maginoodle is offline Donating Member
    vy series2 ss crewman
    Apr 2006
    Default vs auto into vr
    Hi all, i have done a search but found conflicting answers.
    A mate just wrote off his vs and has found a vr that has a stuffed auto.
    Will the vs auto go into the vr?
    In one thread it says that i will only need to change the rear extension housing and in another thread it says i will need to change the valve bodies over which has one of the electrical conectors on it.
    Can anyone clarify which is correct?
    I just found out he wants to do it so i havent looked at the gearboxes to see which variants they are.
    Any help appreciated.
    Cheers Shane
    heres my ride, i know its not much but its mine
    http://forums.justcommodores.com.au/...-ss-crewy.html
    and heres my new project
    http://forums.justcommodores.com.au/...ml#post1104629
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    4hdd boxes have the 1 less pin,
    5hdd and above has the extra pin, so it comes down to what the car has orignaly as to what needs to be done
    if it needs the extra pin he needs to do the extention housing and wiring loome
    maginoodle's Avatar
    Apr 2006
    thanks moff, so if the vs is the 5hdd i wont need to change anything cause the extra pin isnt needed?
    i am guessing if i was going from a car with a 5hdd and wanting to use a 4hdd i would need to change the housing but since i am going the other way the extra pin wont have a wire going to it so it doesnt need to be changed.
    Is that correct?
    Cheers Shane
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    you wont get torque convertor lockup with the wrong box one had 2 solinoids for lockup the later vr and vs box the early vr box had one
    moff_man's Avatar
    Nov 2008
    if you are putting a 5hdd in a car orignally equipted with a 4hdd it should be fine i think. if you are putting a 4hdd in a car orignally equipted with a 5hdd the mod needs to be done
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by chrisdoesitbetter View Post
    how can the two different gearboxes be distinguished?
    Count the pins in the connector maybe, I think the 4HDD has 12, 5HDD has 13.The 6HDD has 13,I know that for sure 100%.Looked at one not long ago that was out of a smashed wagon.
    VR 3.8L
    May 2009
    ok thanks, but what does the number before the HDD represent? capacity, or how many gears etc?
    VX II Calais LS1
    Jan 2010
    the model year it was fitted to, 4HDD 1994? 5HDD 1995? 6HDD 1996?
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
    vr acclaim wagon, vs wagon (project) & vx belina
    Apr 2010
    brisvegas
    Quote Originally Posted by bandit10 View Post
    well my 93 vr has a 6hdd, whats the theory in that???
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by glennis View Post
    Its obviously not the original box then.
    VX II Calais LS1
    Jan 2010
    Brett is correct, you most certainly have a VS trans in your VR
  1. Auto VX V8 Gearbox Swap (with another auto)
    By Tom4321x in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-02-2010, 09:21 PM
  2. difference between standard auto and turbo auto
    By Nackerz in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-11-2009, 08:56 PM
  3. Changine from Column Auto to Floor Auto
    By VNCPTR in forum General Discussion
    Last Post: 16-04-2009, 01:48 AM
  4. Fuel Mileage Holden VZ Wagon(auto) Vs Subaru 2.5(auto)
    By phantomwalker in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-06-2008, 06:38 PM
