Results 1 to 12 of 12
Thread: VS Calais Steering wheel makes annoying noise when turning
    VS Calais
    Apr 2010
    Dandenong, VIC
    Default VS Calais Steering wheel makes annoying noise when turning
    Hey Guys, ive got a VS Calais and when i turn my steering while it makes an annoying noise, i dont know how to describe it, it doesnt seem like a big problem but im just sick of hearing it.
    Ive changed my Power steering fluid thinking it would solve the problem but... i was wrong.
    Thanks.
    vs commodore
    Oct 2009
    Tamworth NSW
    If its a moaning ,groaning type of sound,it will most likely be the bush where the steering column goes through the firewall into the engine bay.Just spray some wd 40 up into the area where it goes through the firewall from the engine bay side and it shound quieten it down.Its a bit awkward to get to but just get it down in there and spray upwards into it.
    VS Calais
    Apr 2010
    Dandenong, VIC
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    I used a long thin stick to apply some grease onto the bush from underneath. That should last longer than WD40.
    VQ Caprice II
    Aug 2006
    on most vn-vs models, the annoying sound originates from the brass ring that makes the horn pad work, there is a brass pin that rides on this brass ring, usually it has some die-lectric (spelling) grease to ensure contact is made, but also to enable it to glide without the noise, to fix, remove steering wheel, but be careful with air bag. I am sure somewhere in this forum are instructions to do this. To test., if I am on the money or not, turn the steering wheel while pulling it away from u, if the sound decreases then that's ur problem. Hope this helps.
    RazzaCaine is offline Long Gone Now
    Mar 2010
    turn the steering wheel while pulling it away from you? what do you mean exactly? how can you pull the steering wheel away from you? pulling it would bring it towards you. my car is making the noise described in the initial post and its bugging me big time. could someone post a picture of the bush i need to grease up? im a bit mechanically illetirate
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    get under you car, where the steering column meets the steering rack (the thing that connect to both wheels and turns the wheels) follow it up until you can see it going inside the car. coat it with wd40 or penetrate etc.
    Mar 2010
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    +1 WD-40/RP7 and or Grease to the gromit fixed it for me. Its tricky to get grease into the right area so I'd suggest some sort of spray lubricant to make things easier.
    I fixed mine by removing the panel above the brake/accel pedals so I could get to the part where the steering column meets the firewall, RP7 down there fixed it in seconds. saves you getting under the car.
    VQ Caprice II
    Aug 2006
    ok sorry haven't been online in here in ages.
    to explain further, sit in the drivers seat, then grab the steering wheel at 12 and 4 pm, pulling it out away from the steering column, then turn it slightly if there is no noise then it is the brass pin that makes the horn work that runs on the brass ring on the bottom side of the steering wheel, it's a common thing. to fix remove steering wheel,(i am sure someone has written a how-to in here somewhere) and then grease it with some dylectric grease then no more problem. Perhaps send me a PM, and we can talk via phone? UP to u.. hope this makes sence
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by spirto View Post
    If the car has an airbag there is no brass horn ring used.The airbag/SRS models use a clock spring instead.The non airbag/SRS models use the brass ring still though.
    Mar 2010
    thanks spirto, that makes a lot more sense now. i thought that was what you meant but the initial wording didnt make it logically possible. mine car doesnt have srs so itll have the brass ring. ill check that out as well. it probably could use some greasing up
  1. Rear wheel hub replacment, or bearings, loud hum noise when turning at 50+ km/ph
    By welchy92 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-03-2010, 06:25 PM
  2. loud nocking noise in front left wheel when turning.
    By macksvt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2009, 07:57 AM
  3. Power Steering Noise when turning right
    By Kartbro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-08-2008, 10:40 PM
  4. Left Wheel Knocking noise when turning at low speed
    By dj_eddie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-01-2008, 09:37 AM
  5. calais cluster makes no noise
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-10-2006, 04:18 PM
