Results 1 to 10 of 10
Thread: Need help with door locks/central locking VR sedan - climbing in and out
    Stock VR 3.8V6 (Petrol/Gas)
    Jun 2008
    Default Need help with door locks/central locking VR sedan - climbing in and out
    Hey guys....
    First of all just to let you know my key head doesn't function, I lock/unlock my car with the key itself
    Yesterday I changed my whole drivers side door. Being from a different car I thought it best that I take my original handle and key barrel and install to the new door. At first all was working well, then today at the shops i jiggled the key a bit (sometimes jams a little and needs a wiggle) and it locked all the doors except the rear drivers side door because it was already wide open. So now I have a key that wont turn to the unlock position, all buttons are jammed in place, 3 locked and 1 not. The button that's up, wont go down and the buttons that are down wont come up. I have tried the key in the passenger side door but same as driver side, wont turn.
    Any help is appreciated.... Thanks in advance
    Correction... the buttons do move but then return to their original positions without doing any locking/unlocking
    vs commodore
    Oct 2009
    Tamworth NSW
    It sounds like you need a new keyfob to get the central locking up and running again.You can also try getting a new key shank (the metal part) cut,about $20 to $30.These locks seem to play up and get stuck when the lock and key gets a bit worn.I cant get my key to lock my drivers door at the moment,I usually use the deadlock feature but the key wont turn to the left in the doorlock barrel,it only turns to the right.I even got another key cut and it made no difference at all.The key will turn the other way though and unlock the doors if they are locked wth the remote.I looked at the locking mechanism and sprayed some wd 40 on it, but no difference,it looks like it might be one of these rare occasions when a visit to the holden dealer is needed as I want to keep my original key.Otherwise Id just go to the wreckers and get another lock barrel and matching key and swap them over.If you dont mind using a different key to open the door,then just swap over the door lock barrel with one you got from the other door and get hold of the key from the car the new door came from.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Brett - sounds like your problem is the microswitch that the key lock actuates when turned to the left....it can corrode solid or the arm that contacts it can move.
    The OP might try disconnecting the battery then try it again.
    Jun 2008
    Quote Originally Posted by hako View Post
    Yeah I did notice this switch and assumed it was to do with the dead lock feature. It is behaving as though this is or at least close to the problem. I used a paper clip and bridged 2 of the contacts at the loom end (c/locking plug) and all other doors in the car opened, however the drivers door is still locked shut. When I lock the passenger door with the key after doing this it "deadlocks" again and wont open until I short it again. I have taken the handle off (drivers side) and the key/barrel/locking mechanisms all seem to work fine. Have used these with no worries (the same microswitch and loom too) for the last 2 years. Is the BCM confused and thinking it should be deadlocking by default? Sounds silly I know, lol. Are you saying that if I disconnect the battery it will reset something and maybe help my issue? Will try that and let you know how it goes. Have tried also disconnecting the microswitch. Will see how it goes. Worried about getting bum jabbed by my handbrake climbing in and out, LOL.
    vs commodore
    Oct 2009
    Tamworth NSW
    I might have to have a better look at it and see if it is the switch.It was getting dark the other day when I had the door trim off ,so I couldnt see in there to well.But tomorrow morning I will have another look and check out that switch.Thanks hako.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    theres one microswitch on the door handle for deadlocked position so the central locking knows its deadlocked then theres others deaper down to lock and unlock one must be jambed up
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    This is what the microswitch looks like.
    Need help with door locks/central locking VR sedan - climbing in and out-microswitch.jpg
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yeah thats the deadlock one not the one that makes the doors lock
    VZ SV6 AND VL CALAIS TURBO
    Jan 2010
    brisbane
    check to fuse mate mine did that when i changed my door couldn't turn the key
    MR HAVICK
    Jun 2008
    OK... I have found the problem....
    After much stuffing around and whatever I took the locking actuator out of the old door and plugged it in... woohoo, it worked. So I switched em around and no worries. When I took the one out of the replacement door it was a different colour(blue) than the original one I had(black). The part numbers are different too. I checked with the person I got the door from and was told the door came from a Berlina... Not sure witch but I am guessing that either the two aren't cross compatible with the BCMs or the actuator is just stuffed.
    Either way, fixed and working.... Cheers for the help.
  1. Vn v8 berlina wagon door handle latches/ central locks
    By ALOWVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-11-2009, 03:19 PM
  2. Vp central door locks question!
    By Greedy in forum Electrical Wiring / Questions
    Last Post: 08-06-2009, 09:09 PM
  3. Solex Locks and After Market central locking
    By Dellboy999 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-08-2005, 11:17 AM
  4. Door Central Locking
    By Maxie195 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-08-2005, 09:50 PM
