hello i am having trouble with my vs commadore when i start it for the first few minits when its cold it is very slugish when i go to take off i have changed the plugs and leads i have run a full tank of good fuel with ingector cleaner but still having this problem
Try checking for any error codes.Heres the link to the post that shows you how to do this check.----Checking error codes VR/VS (Revised)---If you scroll down near the bottom of the posts in the link there is some excellent pictures of how to do this as well.
i have done that got no code out of it
Did it show up code 12 at all?
yeh only code 12 showed up
Has the air and fuel filters been changed lately? They could be getting blocked up.Make sure the engine oil and the oil filter are changed regularly, also change the auto transmission filter(which you can do yourself easily enough if you have ramps or stands).I found my car ran heaps better when I first got it after doing these simple things.It seemed sluggish too.Also seeing that it happens when its cold, check the temperature sensor that tells the ECU the ambient temperature so it can make the engine run properly when its cold,It might not be stuffed completely, but might be sending the wrong temperature readings to the ECU when its cold.Maybe try replacing the temperature sensor.I think they are only cheap.Try to use genuine holden sensors if possible.
let your car run for a little bit longer then, if your planning on keeping it and dont want blown head gaskets in future you should let it run until temp gauge starts to move.
could be the MAF sensor on the air intake , might need a clean with the maf spray cleaner. or the sensor may be stuffed. with the engine running you can try disconnecting the MAF plug , and see if that makes engine run worse , if there is no change how the engine runs with the MAF plug off, that may tell you the sensor is bad. just a thought .
