Results 1 to 10 of 10
Thread: vt brake upgrade
    vr commodore 5L
    Apr 2010
    Qld
    Default vt brake upgrade
    hey i just put the vt brake upgarde on my vr it all went on good put when i brake its got a knocking noise only when im going forwed tho and the brake lights stayed on but there not now.
    vs commodore
    Oct 2009
    Tamworth NSW
    Brakes arent something you should mess around with unless you know exactly what you are doing.Especially brake conversions.Id be taking it to a mechanic and getting them to check it all out.Something is obviously not right with it.
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Caliper bolts, check them. In general check that the caliper is secure, they can knock around if there lose.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    vr commodore 5L
    Apr 2010
    Qld
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    As Brett_jjj has already stated, take it to a qualified mecahnic to get it checked; before you kill yourself or someone else.
    vr commodore 5L
    Apr 2010
    Qld
    I did have my mate who is a mechanic tell me they should go on with no probs, so i'll get him to sus it out and see what the go is. The knocking noise not all the time, just when I put the brakes on, it dosn't seem to affect the braking capacity, just more annoying than anything.
    vs ute
    Apr 2010
    Um did you buy the rotor rings to take up the hub size difference, they are on ebay for about $50
    vr commodore 5L
    Apr 2010
    Qld
    Default vr brakes
    was told i didnt need the shim the roters i have are the right size 70mm there not 71.5mm what and were are the shims havnt realy been told were there for
    vr
    Jun 2009
    vr commodore 5L
    Apr 2010
    Qld
    Default shims
    got the shims off ebay there on there way. so where do they go around the hub or on the center on the inside of the wheel studs
  1. VT BRAKE UPGRADE - looking for brake line adaptors for vh to vt
    By rusty05 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-12-2009, 02:54 PM
  2. VT brake upgrade onto VS
    By GTP 85 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-09-2008, 12:30 AM
  3. Spongy Brake Pedal after VT Brake Upgrade
    By DJ Ice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2008, 08:48 PM
  4. Brake Upgrade
    By Stewart1000 in forum General
    Last Post: 17-11-2006, 05:24 PM
  5. Brake upgrade
    By mistermeena in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-11-2005, 01:26 AM
