Results 1 to 9 of 9
Thread: Strange gurgling/fluid like sound from behind dash cluster...please help
    Commodoer VS Executive II V6 3.8L
    Apr 2010
    MELBOURNE
    Question Strange gurgling/fluid like sound from behind dash cluster...please help
    I drive a vs exec ii and im getting a strange gurgling fluid like sound from behind the cluster ....guessing its got to do with the air con....any advice/suggestions???
    vs commodore
    Oct 2009
    Tamworth NSW
    It is probably air trapped in the heater core.Try turning the heater on to the hot position for a while whilst driving and see if the noise stops or if it makes any difference.Ive read of a few people on here that have had the same thing happen.Im not sure how they fixed it though.
    Apr 2010
    MELBOURNE
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It may also be to do with refrigerant evaporating in the (you guessed it) evaporater - this will only be heard after switching off...but if it's happening whilst the engine is running then Brett's suggestion looks to be the go. You loosen the bleeder screw located on top of the thermostat housing to release trapped air with the engine idling and heater ON.
    Apr 2010
    MELBOURNE
    yeah its whilst im driving....engine idling meaning in neutral im guessing yes?? i no shit all about cars lol. where is the thermostat housing and is the bleeder screw obvious or am i looking for something in particular??? v6 3.8l. im guessing when i get to it, if it is the problem im gonna hear the air coming out?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    There is a "how-to" on bleeding air in the "how-to" section, but first try turning the temp dial to HOT then go for a short run as this can also remove any trapped air from the heater. I'd also check the coolant level in the radiator - do this when the engine is cold - remove the cap off the right hand side of the radiator (facing car). This must be full. Also make sure the coolant overflow tank is half full of coolant.
    If you plan on fixing your car yourself (and saving heaps of $$$$), I'd suggest you buy a Gregorys workshop manual - they sell for about $50 new but you can pick them up 2nd hand on Ebay for lots less. It will pay for itself pretty soon plus you get the satisfaction of fixing the car yourself.
    Good Luck.
    Apr 2010
    MELBOURNE
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I usually use Nulon concentrate in the 5 litre containers - that will make up to 10 litres of coolant with a life of 3 years - it's about $35 at most stores. The coolant from Holden is also good but costs a bit more. Whatever you use, make sure it says on the container that it's suitable for V6's as there are a lot of cheap coolants that only contain coloured water.
    Good Luck.
    Apr 2010
    MELBOURNE
    i couldnt find the "how to" on bleeding air...could you please send me a link...went for a run with air con on a full hot setting...still gettin the noise...i dont even think the car has fck all coolant in it!!
  1. Gurgling radiator
    By Zillajnr in forum VE Holden Commodore (2006 - ?)
    Last Post: 14-10-2008, 02:33 PM
  2. very strang lpg troubles....
    By stackner in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-07-2006, 07:45 PM
  3. Exhaust Gurgling.
    By Hayles in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-11-2005, 10:34 PM
  4. Gurgling Noise In Vn V6
    By ::Team420:: in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-10-2005, 06:17 PM
  5. Rumbling/Gurgling sound in mates vtII
    By TigerVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-10-2005, 10:17 PM
