Results 1 to 19 of 19
Thread: VR wont start HELP
    vr
    Apr 2010
    Default VR wont start HELP
    Hi all hoping some1 can help first i rebuilt my series 2 engine in my vr 3.8
    it was running and out of nowhere just stopped ,and wouldnt start sounded like timing pulled a few things off and found i had placed the magnet incorrectly and it broke ,so replaced magnet and chain sprocket made sure evrything was lined up again and tried turning over ....NOTHING
    JUST POPPING sound -now im really at my wits end with it if some1 can help it would be greatly appreciated ive tried looking it up but IM LOST
    Thanks Brad
    Kurtp's Avatar
    Kurtp is offline VR Buicks > You ;)
    VR Series 2 V6 Sedan
    Aug 2009
    Pakkey VIC
    vr
    Apr 2010
    Quote Originally Posted by Kurtp View Post
    The hammer is your friend.
    its coming close lolz
    vs commodore
    Oct 2009
    Tamworth NSW
    vr
    Apr 2010
    Quote Originally Posted by Brett_jjj View Post
    Is there spark when the engine is wound over?
    yes there is spark we have replaced the os and the throttle body
    vr
    Apr 2010
    ive also replaced the sensor on front of the timing cover replaced crank angel sensor i just tryed to start again it didnt pop this time but wouldnt fire
    vs commodore
    Oct 2009
    Tamworth NSW
    vs commodore
    Oct 2009
    Tamworth NSW
    You might also have to disconnect the fuel line at the engine bay to see if fuel is getting up to the engine.Can you hear the fuel pump prime for 2 seconds when the key is turned to the ON position?
    vr
    Apr 2010
    ok done the battery NO CHANGE
    also done fuel its fine and checked the fuel pump all is ok
    BUT CAR STILL WONT START
    vs commodore
    Oct 2009
    Tamworth NSW
    Maybe the injectors arent injecting fuel into the engine.Or the fuel pressure is to low for them to run.If you get someone else to wind over the engine you should be able to hear the injectors clicking.Put a long screwdriver on one of the injectors and put the handle up to your ear if you cant hear it properly.Check each one.
    vr
    Apr 2010
    thanks im gonna top up the fuel just going to the servo now
    with the injectors do i put the screwdriver on the rail or the injectors
    you dont have a number do you
    im truly over the bloody thing
    vs commodore
    Oct 2009
    Tamworth NSW
    Yep,put the screwdriver on the plastic injector body itself.Try each one to make sure they are all working.A number?
    vr
    Apr 2010
    hi have to wait now flat battery
    vr
    Apr 2010
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    did ya buy a brand new battery or did ya just charge your old 1? prolly dead battery
  16. #16
    vs commodore
    Oct 2009
    Tamworth NSW
    If theres fuel,spark and compression it should go, One of the 3 is not right.Its likely to be fuel or spark.Unless the engine itself has major problems.
  17. #17
    vr
    Apr 2010
    does any1 have a diagram of the timing ? im sure its all together right all timing gear was lined up im wondering about computer or the control modual under the dash ?
    also do i need new gaskets to replace injectors?
  18. #18
    vs commodore
    Oct 2009
    Tamworth NSW
    You will need new o ring seals for the injectors if you remove them.Id get a workshop manual if you dont have one,A gregorys brand one is the way to go if you cant get hold of a factory one.They are well worth it.Especially when troubleshooting problems like yours.
  19. #19
    vr
    Apr 2010
    ok thanks heeps for your suggestions much appreciated
    keep your fingers crossed
  1. VR V8 wont start when hot...??
    By bandit10 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-02-2010, 10:04 AM
  2. VT wont start
    By stocko1981 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-10-2009, 08:20 PM
  3. help my vl wont start
    By langen in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-09-2009, 09:45 PM
  4. Help my vl wont start
    Last Post: 03-09-2009, 08:46 AM
  5. HELP me vs v6 wont start
    By bedford72 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-07-2006, 09:31 PM
