Notice a mark in my car spot where my car has been leaking in the middle sort of inbetween the rear passengers and boot....someone must have a clue???
only thing that could leak ound there would be fuel or most likely diff oil.
You should be able to poke your head under and should be able to clealy see where its coming from.
can you see what it is? smell it, youll know if its diff oil, it stinks!
cheers lads ill check tomoorw
Sure its not petrol? If it was it would most likly be coming from the drivers side rear wheel well.
Hopfuly not brake fluid!
The Daily VN T5V6
355 VN GRP A REP
how would i no if it is brake fluid!?
well im not gonna go licking the fckin ground...ha isnt there a better way to tell
Smell? Just get under and take a look. If its coming from fuel hoses, fuel, brake hoses, brake fluid.
If its fuel, its 99% going to be your breather hoses, you can see them from behind the access pannel in the rear right wheel well.
The Daily VN T5V6
355 VN GRP A REP
its oil of some sort...its sorta brown slightly orangey colour and i realised its coming from underneath the centre console
Probably transmission oil leaking from the output shaft on the transmission or the vehicle speed sender. I'd park it in a different spot for a few days and see if it reappears.
oh its made a fair puddle after not driving for 2 days and smaller ones beforehand...if this is the problem is it serious and what does it take to fix??
