Results 1 to 8 of 8
Thread: i need help
    VH Commodore
    Mar 2009
    Franga(vic)
    Default i need help
    my vr commodore is playing up the battery light keeps coming on and off when im driving then i go to start it next mornin and car wont start stupid thing thanks
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    VZ SV6
    Dec 2009
    Ballarat
    It may be your inability to punctuate?
    I just love the way other motorists on the highway think it's an unmarked cop car.........
    And Yes, it is a manual
    VX II Calais LS1
    Jan 2010
    sounds like you either need a new battery or a new regulator in the alternator, when the engine is running you need to use a volt meter to check the output from the alternator it should be around 14v with the engine running. If its around 12v or lower your alternator is at fault, if its around 14v when running you need a new battery.
    You can buy new regulators for the alternator for around $50 they screw in to the back of the alternator, or if you know how to use a soldering iron you can buy new brushes for around $5 and solder them on to your existing reg.
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    VN S1 (was VR) V6 Hilux
    Apr 2009
    Worn brushes in the Alternator Regulator. Easy five dollar fix if you have the tools and the brushes from an auto elec.
    You will need to be able to competently use a small soldering iron.
    vs commodore
    Oct 2009
    Tamworth NSW
    The single wire that goes to the rear of the alternator can heat up which makes this wire corrode, this can make the battery light come on randomly.Have a good look at this wire and maybe give it a bend to check its not gone brittle.(theres a sticky thread about it at the top of the VR/VS page called "V6 owners check this out")
    vr stroker v6
    Jan 2009
    townsville qld
    could be the regulator on my vn it had a crack in it and when u hit a bup my volt gauge would jump up to 18 volts so i would be checking that
