Results 1 to 6 of 6
Thread: Weird Engine Noise
    VR Executive S1
    Mar 2009
    Default Weird Engine Noise
    Hey everyone, my car VR Buick 3800 did the weirdest thing today when I started the car this loud ticking noise came from the engine bay and gradually got quieter and disappeared it sounded like it came from underneath the engine bay but not to sure and when driving the ticking or tapping noise got quicker with the revs then slowed as the gear changed then got quick again as the revs went up but yeah when i got home the noise had gone anyone know what it may be.
    The God's envy man, for man is mortal and everything that man witnesses in life is more beautiful.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    you may have a lazy lifter or worse a slowly diying oil pump.
    i would get a oil pressure test done or at least get someone who knows to have a listen
    vs commodore
    Oct 2009
    Tamworth NSW
    Ive seen harmonic balancers cause all different sorts of noises from clicking and whirring to grating to humming sounds and more.The balancer is two metal pieces joined with a ring of rubber and this rubber perishes and cracks which causes the outer part of the balancer to move and around make weird noises.Its worth checking.Get a screwdriver and try to lever the balancer back and forth and have a good look at it with the engine running,it should run straight and true,no wobbles.
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    on cold days my car did it, since oil took longer to get to the rockers so they ticked for a moment then went away as the thick oil coats them. and notice it doesnt do it when warm
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    VR Executive S1
    Mar 2009
    Ok car runs fine now the ticking did not return in the morning when i started her up, there is a slight ticking coming from the rocker covers that has been around for sometime just no where near as loud as the incident I had yesterday, so yeah probably a stuffed or lazy lifter, I have a new Harmonic Balancer, put on only a couple months ago so i will check that later on and I will get an oil pressure test done.
    What I have noticed about the oil pressure pump, is the light that comes on the dash just before you start the car doesn't always light up so what could that mean.
    Thanks for the tips much appreciated.
    vs commodore
    Oct 2009
    Tamworth NSW
    Id replace the oil pressure sensor.They are around $25 from holden.I replaced mine the other day bacause it was leaking oil.If you can, use genuine holden sensors as the cheaper ones can be bodgey and can sometimes cause problems.They just screw out and the new ones come with sealant on the threads already so you just gotta screw it in.One thing to watch is to make sure you only screw it in as far as the old one was in.You dont actually screw them in until they are tight (it can crack the oil filter housing),just as long as its screwed in the same distance as the old one. Mine had two threads showing on the old one,so I left two threads showing on the new one.Ive got no oil leaks now.All good.
  1. weird pulley noise coming from front of engine
    By muney in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2011, 12:37 PM
  2. sv6 weird noise :S
    By yandan in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-01-2010, 09:09 AM
  3. Weird engine noise
    By anarklov3r in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-12-2009, 01:04 PM
  4. Weird Noise in Vp 93 Engine
    By Auzzie_VP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-08-2009, 02:04 AM
  5. weird noise need help
    By bMcgrath84 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-11-2005, 04:07 AM
