Results 1 to 2 of 2
Thread: vr acclaim with code 16
    vr acclaim wagon, vs wagon (project) & vx belina
    Apr 2010
    brisvegas
    Smile vr acclaim with code 16
    hi, i know and have cheacked codes come up with 12 then 16.
    so my question is where is the coolant temp sensor /s? are they a easy fix?
    went for a drive the other day and she got real hot....not in red tho,
    ( guessing air lock) as i unscrewwed breather at thermo housing and let it sit for a while.... then was all good.
    temp gauge sits about 1/4 to 1/3
    i just want to know if code 16 is worth worrying about,
    i have searched about this and i would be here all day going through every post
    thanks for ur help
    vs commodore
    Oct 2009
    Tamworth NSW
    There are two sensors,(actually ones a temp sensor and ones a temp sender),one is for the temperature gauge,the other is for the ECU.They are located above the water pump but recessed back a bit at the top of the engine,the passenger side one is for the ECU.The drivers side one is for the gauge.The temp gauge one will have one single wire going to it which slides on to the sender .The ECU one will have a connector plug and a couple of wires going to it.Id replace it if it were me,it will effect the economy and the general running of the vehicle if the ECU doesnt know the correct engine temperature.I have had trouble with a couple of aftermarket sensors,so if you can, try to use genuine holden sensors, as they wont cause you any problems like cheaper ones sometimes can.They come with 12 months warranty.
  1. '99 VT Acclaim Wagon - Error Code 85
    By mbvp73 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-03-2010, 04:06 PM
  2. my 93 VR acclaim
    By System in forum VR - VS
    Last Post: 15-07-2009, 03:16 PM
  3. Code 72 - Vehicle Speed Sensor (VSS) and Code 73 - Pressure Control Solenoid Current
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2009, 04:39 PM
  4. F/s Vs Acclaim 97
    By SLAMD1 in forum Parts And Other Items For Sale
    Last Post: 12-08-2006, 03:58 PM
  5. Code 14 what the hell is error code 14!@*&%#
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2005, 12:35 PM
