Results 1 to 5 of 5
Thread: Engine troubles V6...help!!
    VS
    Apr 2010
    Default Engine troubles V6...help!!
    My vs v6 heated up the other night on the way home from work (temp gauge got up past red) so when I got home I gave it half an hour then topped up the water (it need 3l to be full) and also topped up the oil which was fairly low. On the way to work next it started to smell hot (but the temp gauge never went past 3/4) then the engine made a tinny rattle sound and lost power was about to pullover and then it just stalled with steam billowing. couldn't restart it so had it towed. First of all thought the engine seized but following day when it was totally cold it started but running rough as guts and steam coming out of exhaust. Thought maybe a head gasket, but pulled the engine apart and head gasket appears fine. Does any one have any ideas, as it is costing a bit with trial and error???
    bloodyricho's Avatar
    bloodyricho is offline Bloody Richo
    Vr V6 Equipe (hare) and VE SV6 (tortise)
    Dec 2009
    littleton nsw
    cracked head maybe not real likely. gunna have to grind the heads now to get them back on so ask machinist to have a gander og get some new heads
    Making and running DUAL CHIPPED ECU SINCE 2010
    BoNeZ-01's Avatar
    BoNeZ-01 is offline "..of mice and men.."
    '95 Cino(daily driver), Project: VS.
    Mar 2010
    Central West, NSW(middle of nowhere).
    If it's not a head gasket, then it 'could' be a cracked head?
    Happens fairly easy to alloy heads, and since yours did pretty hot?
    Sounds similar to the symptoms from a mates old VL, the head was cracked, steam(almost water..) out of the exhaust, running rough and so on.
    We couldn't actually 'see' the crack, weather that's because of where it was, or the fact that it was closed when cold, then opened when hot, I'm not sure.
    EDIT: oops, I forgot to add if they're not cracked, they could be warped from overheating too, which could also cause similar problems.
    On the 7th day, God created Holden, then on the 8th day, God created Ford, to keep idiots out of Holden's.
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost..
    wtf? im not stupid, theres no such thing as a tyre valve
    Dec 2009
    littleton nsw
    i used to pressure test heads in the prentice days they are heated then boiling water is pumped into the water jacket (pressure testing see). but you can get a fair pair of second hand heads for cheap-ish saves paying for prussure test and TIG job cheap answers include Holden Commodore "96 VS V6 3.8Ltr Ecotec Engine - eBay V6 Engines, Engines, Components, Car Parts, Accessories, Cars, Bikes, Boats. (end time 27-May-10 12:48:20 AEST)
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    http://woteva.tk/
    If it ain't broke... I can break it for you
  1. Engine Troubles,
    By andrebennetto in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-01-2010, 09:10 PM
  2. [QLD] VR engine troubles
    By Knights in forum General
    Last Post: 09-10-2009, 07:00 PM
  3. VX V6 Engine Troubles
    By Je[Z]zA in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-02-2009, 01:27 PM
  4. vn troubles
    By william19 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-04-2007, 06:16 PM
  5. Help me with my vn troubles
    By vn_lexcen_s2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-11-2005, 07:41 PM
