Results 1 to 6 of 6
Thread: change live axle lsd oil
    hq-racing's Avatar
    hq-racing is offline HSVR-28
    93 VR CLUBSPORT WAGON DAILY. 73 HQ PREMIER PROJECT
    Sep 2008
    S.A
    Question change live axle lsd oil
    hey, just wanting to know how to change the oil in my live axle lsd.
    do you drain it with the last nut at the bottom, and to fill it up take the plastic plug off?
    what sort of oil is best to use and additive? its a 3.89 ratio.
    thanks
    VR CLUBSPORT WAGON
    yes a clubsport wagon....
    LIVE THE DREAM
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Quote Originally Posted by hq-racing View Post
    thanks
    Yep, remove bottom nut to drain and go get some specific LSD Diff Oil and i think i used a little hand pump to fill it back up when i did it.
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Jack up the rear end so the bung hole is more accessible. If you don't have a pump to refill it use a small funnel. You can add some Nulon G70 to the LSD oil if you like, it quietens it.
    Dec 2009
    Quote Originally Posted by maldotcom2 View Post
    Car should be level to get the oil level in the diff right so you need to jack up the whole car and keep it at the same level it normally sits onthe ground.
    VY SS
    Jun 2006
    Albany
    i used penrite lsd diff oil in mine, the container has sort of a pull out straw thing in the lid which makes it easy to fill up
    hq-racing's Avatar
    Sep 2008
    S.A
    cool thanks for that guys!
    VR CLUBSPORT WAGON
    LIVE THE DREAM
  1. Wll VS live axle sedan, fit in live axle ute??
    By rooooboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-10-2009, 08:08 PM
  2. quick help please vs live axle , axle swap
    By bwian in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2009, 02:20 PM
  3. Will VN Live Axle shocks and springs fit a live axle VR?
    By Andrew426 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-09-2009, 06:33 PM
  4. live axle or IRS?
    By jayderichards in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-04-2008, 02:59 PM
  5. R31 LSD into VS Live Axle
    By overgrown in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-01-2008, 06:29 PM
