vs bcm key
Hi,
I have tried researching but am very confused now,
On a vs v6 auto
If I am doing the manual conversion and found wiring is different and computer.
If i plug in a t5 vs manual ecu and wiring do i need to get the bcm or key reprogrammed
to the ecu?
thanks.
no.
only in vt onwards does the bcm have to be 'programmed' to the ecu.
vr and vs use a more primative system
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
