Results 1 to 9 of 9
Thread: Vr runs fine when its cold but when it gets warm...
    vr berlina wagon 3.8l
    Feb 2005
    Default Vr runs fine when its cold but when it gets warm...
    Over the past two weeks my V6 vr commodore starts to cough and splutter when I accelerate, but it only seems to be when it is warm. Runs fine when the engines cool. Any Ideas on what it could be? TIA
    vr acclaim
    Apr 2010
    vs commodore
    Oct 2009
    Tamworth NSW
    As above,check for any logged error codes.---Checking error codes VR/VS (Revised)---If you go into this link and scroll down near the bottom of the posts,there are some excellent pics as well that show you how to do this test.
    vr acclaim
    Apr 2010
    Feb 2005
    did the error code and all is fine. took it for a drive to get it warm and retested, error code is still 12. What sensor would it be? Could it be dirty injectors?
    vr acclaim
    Apr 2010
    just make sure its in neutral and wait a min u should get 3 flashes of 12 then anything thats wrong should come after that do u c anything leakin from them could b that or check u fuel filter
    Feb 2005
    No, nothing leaking from injectors, changed fuel filter but it has made no difference. the diagnosis keeps coming back as ok I have checked it quite a few times. Think I might just take it to the mechanic but if anyone has any other suggestions they would be welcome
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Ignition leads?
    VS executive
    Jun 2009
    Quote Originally Posted by commodoryhory View Post
    i had a lead touching an extractor which would cause a cylinder not too fire sometimes , it looked fine but when i pulled on it its broke into pieces.... so check the leads, plugs and coils is my guess.
  1. Dual Fuel Commodore VX runs lumpy at 80kms/hr but fine on LPG any clues???
    By blueracer70 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-03-2010, 10:03 PM
  2. Runs Fine on Gas, **** on petrol
    By mrhotdog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2008, 05:26 PM
  3. V6 runs cold, slow to warm, doesn't hold temperature, bad fuel economy
    By fixedit in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2006, 10:11 AM
  4. Runs fine, no logged errors, excess fuel
    By digisol in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-08-2006, 11:12 AM
  5. heat problem - runs fine, starts to misfire then dies
    By mgvl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-09-2005, 11:01 AM
